Roll Center kit on non lowered Evo?
So I think I have a bad lower ball joint, and looking at my options the white line kit seems to be the best one. I just got the car a couple of weeks ago and is not lowered yet and I was trying to put that off til the spring. My question is will there be negative effects of having the roll center kit on a stock height car or should I go ahead and spend the money to lower it as well?
From my understanding via a local shop, it is not absolutely required on a stock ride height or slightly lowered evo but highly recommended if you want to go very low or if you do any type of competition or club events.
I know it is not required on a stock height Evo. I am asking if it is ok to use it on a stock height Evo. I thought I read somewhere that it was nto to be used with stock height cars.
works fine on the stock ride height evo and improves the camber curve and still helps the dreaded body roll. wHEN i'M ASKED FOR MY bANG FOR THE buck MODS I go to the rear sway then front roll center....
