Coilover Spring inner diameter
Old Dec 19, 2009 | 06:10 PM
Yoshi W's Avatar
How does the inner diameter of a coilover spring affect it, such as larger inner diameter vs smaller inner diameter? thanks!
Old Dec 19, 2009 | 09:59 PM
GTWORX.com's Avatar
Well...it's not something people generally worry about. You just get something that fits and is a common size so you can use the springs you may or may not have left in your garage. 2.5'' and 60mm are both common sizes so most manufacturers stick with those sizes. I think 60mm is a little lighter, but 2.5'' is a little more consistent in terms of rate. But there is very, very little difference. I try to use 60mm because i have a shelf full of 60mm perches and hardware...
- Andrew
Old Dec 21, 2009 | 04:31 PM
Yoshi W's Avatar
Thanks for all the help! a quick question, do you by chance know the size of the perch on stance gr+ coilovers?
Old Dec 21, 2009 | 05:51 PM
GTWORX.com's Avatar
my guess is 65mm, which you can sometimes use 2.5 inch springs with, but i'm not sure. call stance.
swift does make 65mm springs.
- drew
Old Dec 22, 2009 | 04:25 PM
Yoshi W's Avatar
alright, thanks for all the help! and one more quick q, how much does the length affect the spring? so for the swift coilover springs, what length would you recommend?
Old Dec 22, 2009 | 05:34 PM
GTWORX.com's Avatar
give us a call tomorrow....i might not be in but myles can help you.
- andrew
Old Dec 25, 2009 | 08:09 PM
Yoshi W's Avatar
k, thanks for all the help!
Grimgrak
Nov 19, 2014 02:51 AM
an2ny
17
Jan 18, 2013 08:16 AM
Miller_x
Oct 14, 2012 10:54 PM
05_VIII
Jun 23, 2012 10:34 AM
Hassan!
Jan 30, 2010 05:56 AM
