roll bar upgrade rear or front first?
Old Jan 5, 2010 | 05:25 PM
leecavturbo's Avatar
roll (sway) bar upgrade rear or front first?
if on a budget which to get first?
Old Jan 5, 2010 | 05:56 PM
chu's Avatar
chu
1. What is the current suspension setup?
2. What is the car used for? DD street performance, Track, Autox, combination?
3. What is your budget?
Old Jan 5, 2010 | 06:11 PM
bilstein hd with swift spec rs
dd with some autox
not alot
Old Jan 5, 2010 | 06:16 PM
chu's Avatar
chu
With that said, then I recommend a 25mm rear bar. Most are 3 way adjustable, so any will do. Most people will argue weight between hollow and solid, and ridgity and whatnot. I personally like the Perrin, as it comes with the stout mounts. Whiteline also makes a nice bars, but uses stock mounts. RRE also makes a budget-friendly bar thats effective. I'm running a Robi 27mm myself. GL.
Old Jan 6, 2010 | 03:33 AM
Smike's Avatar
Just was a thread on this.
https://www.evolutionm.net/forums/ev...lp-needed.html
