Coilovers - Damper and Spring Settings
Old Oct 28, 2003 | 11:22 AM
kam's Avatar
kam
Question Coilovers - Damper and Spring Settings
I have a set of Cusco Zero 2R's. I am wondering what settings should be used for the dampers and the spring preloads to reduce understeer/increase oversteer for autox.
Old Oct 29, 2003 | 11:23 PM
silver bullet's Avatar
I have found 4 in the front and 5 in back to work well. The abs control unit is setup for a 60/40-weight balance so corner weight accordingly, set the toe to +2mm front and rear. Ralliart bushings will help some to.
Mark
