FD RX7 Wheels and 20mm Spacers PICS NEEDED HELP
Old Feb 22, 2010 | 09:05 PM
Gordian79's Avatar
Originally Posted by chu
Both versions are 16x8. However, Mazda changed the design because there were complains about the wheels design being weak and cracking under stress. The earlier models were 13.X pounds. While the 2nd version is redesigned and stronger, it also weighted about 2lbs heavier. If you look behind the wheel, the back of the faces look slightly different. Also, the design of the wheel barrel is also different, and only one version fits over the Brembos on the Evo.
Okay, finally have pics to show what I've been talking about in countless threads about this topic... I hope this clears up some confusion for people trying to fit these wheels.
See the difference in face design?
See the difference in barrel design?
I see the difference of the design so which one will fit evo left or right
Old Feb 23, 2010 | 05:16 AM
chu's Avatar
chu
In the second pic, the one on the left is the one that fit.
Old Feb 23, 2010 | 03:01 PM
Gordian79's Avatar
How about on first pic?the bell design or the square?I ask just in case wheels have tires on them it's easier to tell by flange design.
Old Feb 23, 2010 | 03:21 PM
chu's Avatar
chu
Honestly, I don't know. In the first pic, the one on the right is the stronger one. However, I'm not sure which wheel has the rounded barrel design vs. the "squared" designed.
Old Mar 8, 2010 | 07:48 PM
DOUGLAS's Avatar
bump anyone?.....
Old Mar 8, 2010 | 07:52 PM
DOUGLAS's Avatar
People running RX7 FD Wheels: Look here please!
Can someone take a picture of the barrel if they have some laying around without tires? Could you also take a picture of the backside of the face? I am trying to figure out which wheels will work being there are 2 versions. THANK YOU.....
Old Mar 9, 2010 | 05:49 PM
Smike's Avatar
Ah, see post 10 in this thread.
https://www.evolutionm.net/forums/7974470-post10.html
Old Mar 9, 2010 | 06:03 PM
DOUGLAS's Avatar
Originally Posted by SmikeEvo
Ok so if you think you are right then please show us which one will work in regards to the back of the face. The answer is not in this thread.
Old Mar 9, 2010 | 06:05 PM
DOUGLAS's Avatar
Point Proven
Old Mar 9, 2010 | 06:06 PM
Smike's Avatar
Good, now maybe someone who has them will look into this thread and answer you.
Edit: PM olmoscd - he has them.
Old Mar 11, 2010 | 08:09 PM
EVOlutionary's Avatar
Ask and ye shall receive!
The pic from the rear - the right one fits.
The pic of the rim without tire - the left one fits.
They are the same version - the later, stronger version. In the rear pic you can see how the thickness in the spokes is increased in the later version to increase strength.
I have a set and they are marked "50". This is the type that fits and this is the one shown in the above referenced pics. . .
EVOlutionary
Old Mar 11, 2010 | 09:06 PM
Evokid03's Avatar
Check you Pm ILL TAke care of you
Old Mar 12, 2010 | 03:12 AM
Smike's Avatar
EVOlutionary
EVOlutionary wins! (I am sure you have heard that before. )
Old Mar 12, 2010 | 08:18 AM
Evokid03's Avatar
These Wheels Fit as i run them on my car with factory Brembo's.. Also forget those bolt on 20mm spacers, i have custom made 20mm slip on spacers that fit amazing. (Wheel centric and hub centric).
Old Mar 12, 2010 | 07:35 PM
^^^ Do you have contact info for where you got the spacers or who made them for you. I sure could use a set!
