Any one got a suggestion?
I was looking into buying a coilover suspension system and wondering what everyone thought about which is best. My Evo is a DD in Summer and has 480hp. does anyone have any godd suggestions? Any would help Thanks guys
Id like to track it in this season coming up. I am currently runny stock wheel/tire size.
Just wondering but why would you suggest just springs and not full coilovers?
Thanks for the insight though guys.
Better handling on the street and for the track. More Adjustable for going from one to the other instead of just lowering springs. Why would you not go to coilovers? Whats the biggest difference besides the adjustablilty?
unless you get some high end coilovers (like ohlins, kw or similar) the most cost effective way to improve on suspension is a nice set of bilstein hd with springs, or even the mr bilsteins revalved to your needs. The thing is, coilovers need to be set up properly for you to take full advantage, and most of the time the ride/handling get compromised when installed a set of so so coilovers.
If you still want coilovers, on a 2k budget, and use your car mostly as a DD, then get the bilsteins PSS9, I have them, I love them.
If I could do it all over again, I would get the HD's, with a set of swift springs. Cheaper, easier to set up, great handling.
Good luck.
Good luck.
Coilovers aren't very good until you get to PSS9's at around $2k IMO. Anything less than that and you should stick with Bilsteins and a good set of springs (our GTWORX springs or Swifts). Maybe add swaybars and some bushings/geometry parts.
- Andrew
- Andrew
