need alignment suggestion!
Old Feb 26, 2010 | 03:36 PM
n2oiroc's Avatar
03 evo. stock suspension except swift spec r's and 255/40R17 star specs. im looking for decent tire wear and neutral handling with maybe a touch of throttle induced oversteer. i appreciate the input!
Old Feb 26, 2010 | 03:38 PM
MitsoKid's Avatar
Camber front -2.6, 0 toe
Camber rear -1.8 or less, o toe
Works good for me
Old Feb 26, 2010 | 03:51 PM
n2oiroc's Avatar
Works good for me
stock bolts work or do i need anything?
Old Feb 26, 2010 | 05:36 PM
MitsoKid's Avatar
possibly camber plates up front. Forgot about that? I would tune for as much possible negative camber, I've had good results doing that. If you want a touch of oversteer play around with the rear camber once you have the front dialed in. Less rear - camber usually translates to more oversteer in an on-throttle situation
Old Feb 27, 2010 | 05:54 AM
Smike's Avatar
What you asked for does not totally rely on the alignment.
But us the -2 bolt selection, should get you -1.7 to -2.1 actual front camber. Run -1 to -1.5 camber rear. Zero toe all around.
Please search, topic well covered.
Closed.
dtmevox
Feb 10, 2016 08:07 AM
Dmotorsports
Feb 5, 2016 07:55 AM
eVoRox
Jun 9, 2014 07:28 PM
Paulnsx
Northeast Region
May 16, 2013 10:02 AM
emagdnim8
Midwest Region
Feb 8, 2009 09:27 PM
