staggered wheels
staggered wheels
ok i have searched all the threads looking for pics of staggered wheels on a evo 8/9. lots of people talk about but no ones posted pics. its like the lock ness monster or bigfoot everybody talks about it but no one has a good pic of it.i see spec. tire setups no pics does any one actually have any?
What exactly are you looking for? Some folks running slightly wider front wheels for autocross, but only slightly. For example 18x10.5 front and 18x10 rear. Those cases they also run the _same_ size tire so the circumference is the same. There's not much to see...
d
d
The bottom line is you can't run different diameter tires front and rear on an AWD vehicle without eventually doing some damage. Even running the same size tire on two different width wheels will cause problems since stretching the tire will reduce its diameter. Depending on what you're looking for there are plenty of people who run staggered offset wheels though which may achieve the look you're going for. It is possible to run a wider tire at one end as long as the diameter is the same, for example Dunlop Z1's are the same diameter (according to tire rack) in 235/45/17 and 265/40/17.
Really? Have you measured it?
I have. A radial tire will have very, very close to the same circumference over a wide range of wheels widths, certainly over the range of "recommended" widths on tirerack's website.
d
Hope things are great for you back in the RGR btw
^ I had the same setup, assuming the +18 F is a +38 with a 20mm spacer.
If not, you would have to dismount the tires to rotate them every time, instead of just the wheels, which is a waste of time, money, and unless you're really into spending a lot of both, usually tread as well, just to run staggered setups that can't be rotated front and rear.
That's always been what I don't understand about running staggered offsets on AWD. Why make rotating so much more complicated for just a few mm of offset? I'd rather be racing and easily swapping wheels to rotate than at the wheel machine/shop, or just wasting tread. Really doesn't make sense, but that's just me,
