CiroDesign Camber/Caster plates
Nollij,
Guillaume & I pressed in your bushings at my house last night.
To Rick,
Since I've never met you, let me preface: I'm not attacking you. I'm simply making sugggestions as to how you can improve your product.
The way your plates come from you, they are not compatible with the PSS9 shocks. To say you have to buy this other part from this other company is fine, but your plates + PSS9 shocks does not equal working suspension. Just trying to save someone else from assuming that they can throw these on PSS9's on Thursday night, get aligned Friday, and go racing on Saturday. That is not the case, and the reason why I took the time to come here and post.
I love the thicker plates. I've bent a set of thin plates and I wasn't jumping my car (well... maybe the curbing) ANYWAY: I really like the camber, caster adjustment of your plates.
The radiused support for the countersunk fastener is a no-no. To me it says either you're not an Engineer or you had a ball nosed end mill...and it was easier to make a linear pass on a manual mill rather than machine the correct chamfer. FEA what you've built, it'll literally scream at you.
To Rick,
No offense taken.
AFAIK, no plates fit the PSS9s with out changing out the more common smaller nut. We now stock the larger nuts for PSS9 users - No extra cost!
Rick
Rick
the issue with the high pressure area under the fastener is that it will loosen under cyclical loading.
As you load the fastener in tension it compresses (or as Nucci and I like to say, "MUSHES") the material under the head out of the way. This generates an indent in the aluminum. When the load is removed from the fastener (or just reduced) there is now a clearance (gap) instead of an applied clamping load. This will make the fastener seem to "randomly" loosen itself.
This will happen until the head of the counterbored fastener mushes the rest of the aluminum out of the way and makes a proper tapered seat for itself.
Thanks Rick,
General question... if you have these at 6 degrees caster, how far does the center of the wheel move back towards the doors (away from the front bumper?) Trying to figure out where the wheel is going to be with the Perrin PSRS & these.
Thanks
Thanks
The Tein top nuts worked great for the Bilstein PSS9s. The plates look great and the car is feeling pretty good with all of the new suspension mods put on it (Ciro plates, Bilstein PSS9s, RCA, bushings, bumpsteer correction).
Unfortunately I have not been able to put everything to the test as it has been raining out. I definitely notice a significantly better response on my turn in but unfortunately due to the wet roads, I don't want to put the corner exit response to the test.
Hopefully it will be sunny for the last AutoX of the season.
Rick
Good luck at your next race. I dialed in some more front neg camber and did well last Sunday, besting some national champs and top street tire drivers at this year's nats.
http://members.quixnet.net/free2000/cscc092511pax.html
Rick
sorry to bring this back from the dead, but has anyone come up with any good/easy ideas to mark these to say have two settings to switch between?
these will more than likely be the plates i run, but in planning ahead i might look to be able to switch between two camber settings and dont want to just scratch a line on them or something stupid lol.
Scratching a line is what most do... or use an engraver or lay down some tape and use a marker...
Whatever works best for you... main problem is the toe change that accompanies any camber change
best of luck and let us know what you came up with
On an evo more neg camber causes more toe-in. So if you set your race setting for toe-out or zero, a less neg camber "street"setting would have even more toe out. Toe wears tires much much more than camber. So just run zero toe, and with aggressive driving, the tires should wear evenly. Also rotate front to rear if you have the same offset wheels. That said you can us a Sharpie to mark the 2 setting. Also look at the caster plate pdf on our web site, for advise on how to set the plates to optimize the suspension geometry for optimal roll center, and for maximum tire clearance.
Rick
From: Why do they always call the Evo the Dark Side?
Bump... just found this thread while looking for the Torrington bearing information. Just reminded of how happy I am with these plates
Thanks for a great product Rick! Let us all know when you do the front swaybar mounts
