Shaking steering wheel at 70mph
Old Jun 30, 2010 | 10:19 AM
  #46
barneyb's Avatar
Too many cars involved with too many vague symptoms.....In the end I think this is going to come down to big wheels and wide tires being balanced on balance machines good enough for other cars and almost good enough for our cars.
Old Jun 30, 2010 | 10:25 AM
  #47
silver97's Avatar
I had a problem like this and it was rotor. Put the car on a lift pull tires off and rotate rotor and if you hit a tight spot its the rotor.
Old Jul 1, 2010 | 06:06 AM
  #48
Kevmac3685's Avatar
They have nothing to do with it, I'm fairly certain about that. For the record I don't know anyone who has taken those off and all my friends run a 3" dp.
I agree and I still have mine on but my friend is a soon to be mechanic at a mitsu dealer. He just came from a subie dealer. He turned over to the dark side lol. I would think he would know more about the car then most people I know since he works on that particular car.
Old Jul 1, 2010 | 06:14 AM
  #49
SubieEvoGuy's Avatar
are you driving on the bumps on the side of the road =p
Old Jul 10, 2010 | 08:58 PM
  #50
Hearts_Fitment's Avatar
I have the same problem, my Mitsu dealer diagnosed it to be a bent rim. Which is common, but I just read through the thread and nobody mentioned it. So I figured I'd throw that in there too.
What was this about the hub rings? Can this cause steering wheel wobble at 70mph?
Old Jul 11, 2010 | 02:08 AM
  #51
VROOOM's Avatar
It might be hub centric rings or possibly a stuffed driveshaft. Have you gotten a proper diagnosis from a mechanic yet?
Old Jul 15, 2010 | 03:50 PM
  #52
dvd_mi's Avatar
Lately I took off front rotors and drove without them. Still shaking, so it's not rotors. Since its not tie rods, not bearings, not ball joints, not wheels, not tires, not bushings, not rotors and not steering wheel (tight, no play), then I don't know. I am out of ideas what might cause it.
Old Jul 15, 2010 | 04:01 PM
  #53
leonevox's Avatar
got to be them cheap aftermarket wheels. It's nothing to do with the people that balanced it. I balanced my car 5 times with different shop, still shake. Stay out of them cheap wheels. Put new front rotors & pads help too. If your evo are 2005, suspension parts are fine , no problem. Just try on different wheels and see.
Old Jul 15, 2010 | 04:04 PM
  #54
leonevox's Avatar
Only use hudcentric wheels. You do not want to use wheel that require hub rings. And stay away from wheel spacer too
Old Jul 15, 2010 | 04:06 PM
  #55
leonevox's Avatar
where do u live? dont drive behind me without them rotors brother what wheels are u using?
Old Jul 17, 2010 | 01:47 AM
  #56
dvd_mi's Avatar
I guess you didn't read whole thread. I swapped the rims (Konig) for stock (Enkei) ones, because I have two sets (rims+tires). That didn't solve the problems. Still shaking.
Old Jul 20, 2010 | 08:20 AM
  #57
leonevox's Avatar
well sometimes stock enkei shake too. I had 18" rota on, no more shaking. Not all wheels are perfect, stock wheel might shake too bro.
Old Jul 20, 2010 | 05:30 PM
  #58
scorch's Avatar
mine was doing this aswell... ended up bieng a warped rotor
Old Jul 21, 2010 | 05:13 AM
  #59
dvd_mi's Avatar
Yea, I understand, but two sets of rims with the same problem. I don't believe.
Old Jul 21, 2010 | 05:31 AM
  #60
jason05evoviii's Avatar
Yeah, that's what my problem was.
Humm......never knew your car would shake by changing wheels?
