Rota grids scrapping ;(
Old May 12, 2010 | 12:40 PM
mitsuevodriver's Avatar
Mines comes like this...... How am i suppose to adjust the two back ones with just two bolts.
Two back ones are in the middle. Heres the picture:
Old May 12, 2010 | 12:42 PM
shh!! sleeping's Avatar
Relocate the bracket where the bumper connects...
Old May 12, 2010 | 12:44 PM
how do i do that?
Old May 12, 2010 | 01:06 PM
8UpUrV8's Avatar
Have you gotten an alignment since the coilovers?
That's the best way to adjust camber so it can be even on both sides..
Old May 12, 2010 | 01:14 PM
Nope i havent. But 8UpUrV8 what did you do? Did you just leave it? Could i hammer it in more?
Old May 12, 2010 | 01:17 PM
delongedoug's Avatar
There is a bolt where the bumper meets the car inside the wheel well. This needs to be relocated. In other words, remove it and drill a hole elsewhere. I haven't had to do this myself but I know for a fact there are threads on it.
PM'd you about how to adjust rear camber, but if you put coilovers on and haven't had an alignment yet, this will just help your rear rubbing issue. You will still need a full alignment as I'm sure everything's all sorts of out of whack.
Old May 12, 2010 | 01:22 PM
So after i relocate it i could hammer in the sticking out part? right?
Old May 12, 2010 | 08:35 PM
How am i suppose to cut it? lol...... But bumps!! help whoever has done it.
Old May 14, 2010 | 01:08 PM
Solo II Evo's Avatar
All you need is to align it properly. That's it. I run 18x9.5" NT03's with a 265/35/18 tire and no rubbing.
As Deloungedoug said, there is a camber adjustment bolt in the back (this is not the bolt on top). Look up where this bolt is (It's the third bolt closest to the center of the car on the rear lower control arm, you'll see tick marks on it). If you run a little more negative rear camber, you'll be all set.
Don't go buying new tires.. lol
Old May 14, 2010 | 01:42 PM
Mike.p's Avatar
i just got an alignment and am running -2 camber all around on stock struts/shocks..... i also have 255... i still get a little rubbing were that bolt is so im going to try and grind on it a little...but im lowered on tien stech...if i was on coilovers i would have any probs.
Old May 14, 2010 | 04:45 PM
Even though it's out there and you should be searching, here's what you need to adjust rear camber:
It is the bolt that is labeled #2 on the left, the inner-most bolt on the car. First loosen the nut and then you can turn the bolt with the big flat piece on it that has a hole drilled and tick marks like a ruler. This will move the arm in and out causing the bottom of the tire to move in and out, giving you negative camber.
Old Jun 25, 2010 | 08:35 AM
RandomLaosGuy's Avatar
Originally Posted by mitsuevodriver
Yeah im running 245/40/18 right now. But it still scrapes ;( Sometimes it scares me. LOL!!! Ill get some pics in a bit.
Wheels: 18x9.5 +20
Tire size: 245/40/18
Suspension: D2 coilovers.
Im running the same wheels, same tire size, but on Tein S-Tech springs.. I rolled my rears a little. My car isnt extremely low though - I dont rub or scrape at all.
Maybe add some neg camber on the bizzzatch
Old Jun 25, 2010 | 04:39 PM
srtboostin22's Avatar
get 35 series tires.
Old Jun 25, 2010 | 07:47 PM
K1tt3n5's Avatar
Relocate the rear bumper mount at least and inch back shave everything in front of it flush. I fit 18x9.5 +12s doing this -3 degrees camber up front -2 rear.
Old Jun 26, 2010 | 12:21 AM
Toxin's Avatar
This thread is so full of fail that it's just amazing.
To the original poster: you installed coilovers - go get an alignment. After that, check for scraping
If Scrapping = 1 go to EvoM; write(post) about ($scraping)
