difference in bfg dr and dr2 aka comp t/a dr
The primary difference between the g-Force T/A Drag Radial vs. its predecessor (the Comp T/A Drag Radial that is now called the g-Force T/A Drag Radial 2) is that the g-Force T/A Drag Radial offers a broader range of performance. While both tires are essentially capable of the same peak performance, the g-Force T/A Drag Radial makes it easier for the racer to achieve because it's available over a broader range of conditions. This benefit is especially valuable to new racers, some of whom may not yet be experienced enough to get the peak performance out of the g-Force T/A Drag Radial-2. The T/A Drag Radial is more commonly made in sport compact vehicle sizes compared to the DR-2 which as more of a domestic size following.
BFGoodrichg-Force T/A Drag Radial 2
