looking to tighten things up a bit
cars coming up on 55,000 miles of NJ,NY driving.. I am just looking to tighten up the front end a bit.. car is great, however i am getting a strut bearing type clunk, replaced strut tops.... nothing... i havent gotten under the car yet.. i think the ball joints mite have some play however this clunk has been happening for a little bit now.. last time i did 12 and 6 ... and 3 and 9 oclock no movement... we shall see any help would be great
-- things that have been changed..
front strut tops(tqed.. the whole 9)
front sway bar bushings (came with the front sway)
--Things to change????
ball joints, tierods (whiteline????? any warranty with them) any help would be amazing
Use a pry bar in between the control arm and knuckle to check for ball joint play. Pry up with it, then use the wheel to pry it down. You'll most likely get movement that way if the ball joint is in fact bad.
Do the same to check the sway bar end links, just at different points. To check tie rods, grab the wheel at 8 and 3 and try to shake it back and forth. You can also test the wheel bearings for play by placing your hands and 12 and 6.
Hope that helps. My money is on ball joints or end links being bad. More likely the end links.
i got the same problem on my left front passenger. i replaced the front endlinks and it worked a little bit but the noise is still there but not as bad. i'm going to switch the front struts and see if the noise continues on the drivers side. i checked mine for wheel bearing and tie rod problems but they seem fine. i think mine might be a strut problem.
i have the same clunk when i hit bumps thought it might be my camber caster plates wearing out i have slight wheel bearing play on each side but maybe ill have to give the rca's a try fyi nj/ny roads are the worst
