Harbor Freight spring compressor on EVO 8?
Anyone ever use one of these on the front strut of an EVO 8?
SPRING COMPRESSOR
If not, other suggestions?
I know renting is an option, but given this thing's $40, and I have a 20% off coupon, it's probably cheaper.
SPRING COMPRESSOR
I have not used that one. But it looks like it will work. Just check all the bots and nuts on it before using it. I have found that some times they are loose.
Thanks for the replies. I've replaced ball joints on typical upper and lower control arm vehicles where you use the car's weight and a floor jack to compress the spring (talk about freaky) but never a spring compressor. I'll go ahead with the HF tool. For the $$$, why not, right?
That first one you posted the link to is by far superior to the two individual ones you put on each side and have to tighten down one at a time. I have both before just recently investing in the hydraulic one. Honestly for $80 more I would go with http://www.harborfreight.com/hydraul...sor-45860.html or even the air compressor powered one (that's the one I have). I can swap a strut in about 30 seconds with it being off the car vs having to tighten down one side, then the other, or even using that tool above still takes a little bit of time. The progression is the standard two compressors method, then the one you posted, then the hydraulic one, and each being easier than the previous
WTB[MidWest]: AC Compressor
ChrisBond1
Jul 28, 2017 08:53 AM
WTB[Northeast]: Evo 8 ac compressor
Ude Lose
Jun 25, 2017 08:08 AM
WTB[Northeast]: AC compressor
Walter1986
Jun 16, 2014 06:10 PM
stokEd
Nov 21, 2009 10:32 AM
marksae
Dec 12, 2006 02:41 PM
