too big a swaybar?
Old Jun 13, 2010 | 05:50 AM
flyingscot's Avatar
too big a swaybar?
maybe some of the suspension gurus can enlighten me,i have been tracking for a couple of years and ive gotten to the point where i think im a decent driver but its still a work in progress but heres my question,i had a 25mm bar on the back and it felt good but understeered midturn at higher speeds,i had a 27mm bar lying around so i stuck it on there before my next event and it appears to have made things worse,explanation please?
Old Jun 13, 2010 | 06:00 AM
Smike's Avatar
No front bar?
Going too big with RSB can amplify the understeer in the front.
I would put a FSB on the car. Whiteline and Robi are a good ones with adjustments. Swifts are non-adjustable, but lighter.
Old Jun 13, 2010 | 06:03 AM
flyingscot's Avatar
Originally Posted by SmikeEvo
No front bar?
hey smike that avatar you got there looked like my face when i got on track with it,i have a whiteline front bar that is brand new thats sitting at my workshop so i may do that in between events or just go back to the 25mm,it would do the same thing right ?
Old Jun 13, 2010 | 06:06 AM
flyingscot's Avatar
i had the 27mm set on middle hole
Old Jun 13, 2010 | 06:22 AM
Smike's Avatar
Well...in a way. But going to the FSB + the 25mm bar would be what I would do. That would give you more room to adjust for your style.
Adding both bars to my car made a huge difference. Car was more able to rotate in AXing for me.
Old Jun 13, 2010 | 06:51 PM
MitsuJDM's Avatar
I have a love/hate relationship with my RSB. Inner rear wheel lift at WOT tight corner exit, but good off-throttle rotation.
I want a FSB soooo bad. I just don't feel like installing it.
Old Jun 13, 2010 | 07:17 PM
blkmkIII's Avatar
waited till i did the clutch since i dropped the subframe collected 8months of dust and i would have never installed it if the clutch didnt die.
Old Jun 13, 2010 | 09:55 PM
flyingscot's Avatar
so you done it and it worked out,everybody drives different so i dont know what to make of it all so far as far as the "yay or nay"for the front bar,im driving at big willow in so cal and my corner entry at turn 8 is 130 + with the power i have but in the tighter stuff my car sucks right now with the bigger bar,im gonna go back to the smaller bar with the spring rates i have,approx 650 fr and 700 rr,i think 10k and 14k,not sure
e_kobz
Oct 15, 2015 10:47 AM
boostedtres
24
Jan 11, 2010 10:11 AM
04tarmacEVO
Jun 27, 2005 08:12 PM
