changes after first auto x
Old Jun 16, 2010 | 12:15 PM
grillpt's Avatar
Originally Posted by XcreatonX
well ill get more seat time and lean to handle the car better. May look into springs.
any driving tips besides brake early to prevent under steer.
Thanks for the advice.
In fast, out slow... err, wait a second. j/k
Look ahead as much as possible is really the best advise for autox. Always try to set yourself up for where you want to be in the next corner.
Old Jun 17, 2010 | 10:23 AM
evremonde's Avatar
Focus on driving a better line rather than pushing the car harder. I know that my first few events i was driving "comfortable" lines, and also over-driving. Alot of time can be saved by driving a shorter line. Slaloms are a great example of this. However don't simply point your car at the next cone. You have to find a balance.
This will help your understeering.
Old Jun 20, 2010 | 09:52 PM
XcreatonX's Avatar
I was looking into springs and have it narrowed down to robispec and gtworx. Does anyone know the spring rates. robi states his are near stock in the rear but higher in front. and gtwrox just states that spring rates are 20% higher than swifts. As far as camber plates what will work with stock struts?
Old Jun 21, 2010 | 07:09 AM
GTWORX.com's Avatar
Our rates are 290 lbs/in front and 330 lbs/in rear. 20mm drop front 15mm drop for more travel and better geometery.
A farily decent bump from stock both front and rear, but the good travel keeps everything happy.
- Andrew
x03_EVO8x
Nov 3, 2011 07:48 PM
JHakimi
10
Mar 4, 2010 07:50 PM
SpoolnEvo
Mar 24, 2009 07:24 PM
Liqquid
Mar 10, 2008 10:53 PM
xX v0oDo0 Xx
28
Jul 17, 2007 03:33 PM
