Swift -mr spring install, making noise
Old Sep 13, 2010 | 09:45 AM
sti"izzle"'s Avatar
I installed my -r swift sprints this weekend. I had a hell of a time getting the -r spring aligned on the strut and then getting the top perch on and aligned to get the strut top bolt on.
When I go over speed bumps, i hear a "metal" click sound. What do you guys think this is? If the spring needs to be re-aligned on the perches, how did you get it aligned properly. I tried to match up the swift spring to where the stock spring hit the top perch.
I have to lean on one side of the spring to get the top strut bolt through the spring perch.
Old Sep 13, 2010 | 10:00 AM
Genesis8's Avatar
Your springs are not sitting properly and you will have to redo it again. On the struts, there will be 2 or 3 hole on top and bottom and you will have to line it up. Does it make a noise when you turn?
Old Sep 13, 2010 | 10:09 AM
sti"izzle"'s Avatar
I don't think it makes noises on turns, just bumps.
Old Sep 13, 2010 | 10:10 AM
kanyonkid's Avatar
i think its normal.... wait a few hundred miles before u do anything.. they have to "set in"
Old Sep 13, 2010 | 10:11 AM
Genesis8's Avatar
If it doesn't make noise when you turn then you probably have to wait for the springs to settle in.
Old Sep 13, 2010 | 10:22 AM
Smike's Avatar
http://www.evomoto.com/tech_articles..._article_id=22
Old Sep 13, 2010 | 10:27 AM
sti"izzle"'s Avatar
I will take a tire off and see if the holes lineup
Old Sep 13, 2010 | 11:19 AM
Smike's Avatar
Cool beans. Also double check the rubber sections that hold everything in. Notches from springs should be in them too.
