anyone have problems with level in brake res.
Old Nov 29, 2003 | 06:44 PM
Grod101's Avatar
anyone have any problems with the level going down in their res. in the engine bay.... i went to the dealer once and they topped it off but now it seem to have gone down again and the brake lite comes on and off depending if i'm on a hill or stoping or accelerating...... i wanna find out if this is normal or if i have a leak or something.....tia
Old Nov 29, 2003 | 09:45 PM
Diesel's Avatar
you have a leak somewhere... you should not be loosing fluid...
could be a leak in the clutch line as well though... check your fitting on the master...
Old Nov 30, 2003 | 07:44 AM
limey's Avatar
I second that...do you have the clutch line upgrade....?
This part leaking at either end sounds the most likely.
