Tein H-techs on Bilsteins???
Old Nov 18, 2010 | 10:02 AM
Brent IX's Avatar
So I have an 06 MR with the Factory Bilsteins and i want the Tein H-tech drop. All Tein lists for the MR is the S-techs, and im still rockin around on stock rims and dont really want to lower it that far on the stock BBS'.
Has anyone put the H-techs on the Bilsteins? are the spring perchs really that different?
side note.. i dont wanna ditch the bilsteins for KYB's.
Old Nov 18, 2010 | 10:09 AM
xmaciek82x's Avatar
OK, you need to head over to the suspension section and start reading. Tein H-Techs are probably the worse spring for your Evo. Also, why do you think you might have to ditch the Bilsteins for kyb? I don't think you realize how good of bilsteins are compared to any strut out there for an evo.
Old Nov 18, 2010 | 12:25 PM
FJF's Avatar
FJF
Look into GTWorx and Swift springs, or stay with the stock setup, depending on how you'll be using the car. This should give you some search criteria to work with. The suspension forum holds a wealth of information. Good luck.
