Alignment settings, stock Bilsteins
Old Jan 8, 2011 | 08:48 PM
Benja's Avatar
Hey guys,
Got my first road racing event next week and want to check my alignment before heading out.
I'll be running R-Spec semi-slicks on factory Bilstein struts and springs.
Don't trust the suspension shop as they don't do performance much.
What settings should I give them to dial it in to?
Cheers
Ben
Old Jan 9, 2011 | 04:15 AM
Smike's Avatar
Use the -2 camber bolt setting up front. That should give you a true camber of -1.8 to -2.3. I would dial in -1 to -1.5 in the rear. I prefer zero toe all around. Those are the settings I ran on my 8 with Z1 and Z1* tires on the Swifts and sway bars.
Old Jan 9, 2011 | 10:25 AM
rawkus's Avatar
+1
I prefer a little more camber out back though. ~1.75 or so.
Dan
Old Jan 9, 2011 | 12:49 PM
Benja's Avatar
Cheers guys.
Would that be ok on the street too? Or would it chew tyres?
Not a daily, prob only 5-7k miles a year max.
On stock sways too. Just a rear strut brace.
Old Jan 9, 2011 | 12:55 PM
Smike's Avatar
I daily drove on my settings above. Heck, I do 5-7k a month. For a year, you'll be fine.
As a side, for the track day - make sure you have proper brake pads and fluid in there. The Evo generates a lot of heat and OEM cannot take track abuse.
Old Jan 9, 2011 | 03:20 PM
Benja's Avatar
Yeah got that sorted, Motul fluid and decent pads.
Old Jan 9, 2011 | 03:24 PM
Smike's Avatar
Old Jan 9, 2011 | 06:17 PM
Benja's Avatar
Have just been recommended to try 2.0mm toe out at front.
Thoughts?
Old Jan 9, 2011 | 06:52 PM
cfdfireman1's Avatar
2.0MM toe out front and back will help turn in a lot.
Old Jan 18, 2011 | 05:48 AM
fasterbater's Avatar
The front end will bite siginificantly more with 2mm of toe out in front, but don't go too nuts as high speed stability will be sacrificed on a fast (60mph+) corner. It could get skittery and will tramline if the track surface is rough.
I like my toe zeroed but that's on bone stock GSR suspension but that's because of the terrible road quality we have in Quebec.
