Tire / Wheel Fitment Questions
#2641
MinusPrevious:
What is, in your opinion, the best offset for an 18x9 rim?
By "best" I mean the least fender work in the back and the least spacer in the front.
No flush or extreme offset.
Edit: With 255/40/18's
BTW, thanks for all of your input on this thread, you help a lot of people!
The 18x9 +35 is likely a good option & is very modest. Now, the 255/40 is a very healthy tire (255/35 is more common) in the way of circumference. A fender roll will be needed. But in my book I like the aggressive look & the 40 series is beefy
Regarding the front, its all about hub & spoke design that dictates caliper clearance. Its not so much offset related
#2642
Enjoy helping out. Really just giving you guys the basics!
Now the challenge is finding rims in the size...
#2644
https://www.evolutionm.net/forums/ev...-calipers.html
#2654
You didnt note the full wheel spec but I used the following
18x9.5 +22 w/245/40 tire
Maybe you knew this already but the rear fenders will need a full roll & fender pull. Bumper bolt likely will need to be moved
Fronts will work w/some liner rub likely
Suggestion based on running stock camber front & rear
