Tire / Wheel Fitment Questions
#3811
To properly clear, you will need a rear fender roll & bumper bolt relocation. If you really want zero chance of rubbing, you will need a slight rear fender pull (I run a very similar spec: 17x9.5 +30 w/265/40's)
Heres a thread where the seller noted the +28's do clear the Brembos but I would search around further.
https://www.evolutionm.net/forums/sa...888-tires.html
Its possible Astro_Train knows as he know Volks really well. He will chime in, im sure
city (May 21, 2018)
#3812
These are some really nice wheels & aggressive for sure.
What all this means for you... is the CE28SL 17x9.5 +28 is a flushed fitment but your best bet is to call Mackin Industries so they can confirm caliper clearance. Reason I say this is that on the Rays Japanese site, this size and offset DO NOT clear according to the spec char. But like I said above and as shown by Chaotixhoax's car below, the CE28N in 17x9.5+28 DOES clear the Brembos. I have also linked his thread so you can see alot more pics of the car. His car truely was a nice example of function and form and inspired me to run the same size spec but with TE37SLs because it was verified on Rays site as clearing the calipers on the 8/9 without the use of any spacers.
One good thing bout the CE28SL in this size is that it is the LONG rim and has the bigger lip which is consistent as the same lip size of the old CE28N. This is good news as most likely it is the same mold as the CE28N. You want to avoid the SS or short rim as it is much smaller and gives a less "deep" effect on the wheel.
As for tire a 255/40 is always a good tire and while slightly stretched on a 9.5 inch rim, it will give you a much better buffer than running a 275. A 265 oddly enough very few tire companies manufacture it and if they do are obscenely expensive.. with the exception of Federal tires. MinusPrevious runs Federals and gave me some invaluable info when I was deciding on what tire to run... he also warned me, Federals run very wide... about 1 size higher than said size on their spec. So a 255 measures out to a 265... a 265 measures out to a 275. I want this as I hate stretched tires and on a 17 inch rim, you are afforded the extra height distance and allows for a higher profile as opposed to 18s.
UPDATE: I just noticed this on Rays site under the CE28SL... so call Mackin Industries, they may have a special on a set and ask them if they clear the calipers on the 8/9
- ※17x7 1/2JJ 4-100 INSET 43、17x9JJ INSET 10、17x9 1/2JJ INSET 28 scheduled to be discontinued once inventory clears.
I WILL POST MORE PICS ON WEDNESDAY... so stay tuned.
https://www.evolutionm.net/forums/ev...vo-thread.html
if you look closely, you can see how stretched these Michelins are which I am not a fan of. But for the street they should be fine if you want to run them and avoid the hassle of further fender mods or camber.
city (May 21, 2018)
Is2scooby (May 31, 2018)
#3814
^^^ those things look massive Joe... well I am gonna have fun gettin them to fit. Right now though I have a ton of room with the skinny Michelins. Wonder if I should of went with the 255s instead
tires will be here Tuesday. Will mount them Wednesday on the car and adjust the camber and ride height. I dot want to raise it or lower it any further. I will likely have to roll the fronts though and relocate the rear bumper bolt. Those things look super beefy. The Federal site says they have a tread width of 10.8 which is 274 mm. So you are right as to what they measure out to.
#3816
Thanks again guys MinusPrevious and Astro Train. I was able to find another link to chatichoax's evo with ce28n in 17x9.5+28 with 255/40/17 with pics.
https://www.evolutionm.net/forums/ev...ml#post7384261
Last edited by city; May 21, 2018 at 11:14 AM. Reason: added pics of chatichoax's evo from his original posting.
MinusPrevious (May 21, 2018)
#3817
The ride height is on the tall side which could mean he was rubbing but not necessarily. Maybe he liked that stance. Needs to be lower for my liking
If you have other questions, let us know
#3820
well Joe.. you were right.. these things are a beast. I measured them and they come out to roughly 274 mm. They literaly engulf my 9.5 TEs. Here are pic of the Michelin Pilot AS3 255/40s and followed by the 265/40 Federal 595 Evos.
Full lock and usual points of rubbing... the only part right now where the tire touches sligtly is at full lock on inside of the liner which is not a big deal since rarely do you turn the wheel at full lock at high speeds. The rally armors are untouched which I am very happy about to avoid rock chips on the doors. I will likely stay at this ride height. I am getting camber adjusted tomorrow and bumper bolt will be relocated some time next week.
first pic... mid point to full lock.. important it clears with plenty of room since this is likely the most the wheel turns at higher speeds.
halfway to lock on rear section of front driver side. Notice it clears the mud flap.
Astro_Train (May 22, 2018)
#3822
I think a 255/40 would fit just fine as well on a 9.5. But I will take the extra girth because it really changes the look of a 17 inch wheel. For anyone looking to go go this route, you will not be disappointed. The best part of Feddys is they are dirt cheap and great quality. And as long as your Evo is not a DD, you cannot beat this tire for the money. I got a set for just under $400 shipped to my door. You cannot touch any decent tire in a 275 size at this price. So this is definitely my new go-to tire. Especially when trying to avoid stretched looks. You can easily run a 255 on a 9.5 rim and you will get a nice square tire tread measurement of a 265. Which to me is win win. I will post some pics tomorrow once I get an alignment. Started pouring here soon as I got them on the car. Go figure...
MinusPrevious (May 22, 2018)
#3823
Hi Fitment Gurus,
Can anyone comment on whether these will fit well on a 2006 IX on Ohlins CO's (at Swift spring height): ADVAN Racing RZII 18×9.0 +35mm 5×114.3.
They would be wrapped in 255/35/18 RE71R's.
Thanks!
Thanks!
MinusPrevious (May 29, 2018)
#3824
No work required on the front fenders. The one thing you need to find out is if a front spacer is needed to clear the Brembos
Ill search around & see if I can find any EvO threads on this wheel
Is2scooby (May 29, 2018)
#3825
Just when I thought I had zeroed in on a wheel, up comes an opportunity for some VOLK TE37 Sagas in 18x9.5” +38
Tires would be the same 255/35/18 RE71R’s as above.
Does the 9.5” width mean my rear quarters are going to need to be pulled/bolt relocated?
