Tire / Wheel Fitment Questions
#3887
He was just noting that if a 10mm spacer is needed that makes your +22 offset a +12 (22mm wheel minus 10mm spacer = +12). The +12 would really push the wheel outboard & make fitment a bit tough up front
Nicolas (Sep 18, 2018)
#3889
See this thread here: https://www.evolutionm.net/forums/ev...17x9-22-a.html
#3890
Nicolas
Heres a better thread to confirm what is needed to fit these great looking wheels
https://www.socalevo.net/threads/184...olling-fenders
Nicolas (Jun 29, 2018)
#3891
Looks like with a 5mm it clears the brembos. I have to consider now if i will go with a spacer or sell the rims. Thanks guys for the help. Did not expect that installing rims would require a Phd in rocket science. loool
MinusPrevious (Jun 29, 2018)
#3893
Also the question is do you have coilovers because you'll need to camber them a bit in the front and rear for that aggressive of an offset. Rpf1 are sexy but are a pain to fit the flat faced ones. I had the 17x8.5 +30 and needed nothing but the spokes have a different curve
huzzle101 (Aug 7, 2018)
#3894
What tire spec, please?
#3895
i have Leda coilovers and soon Ohlins road and track.
Are these any good?
http://www.streettunedmotorsports.co...el_spacers.htm
Are these any good?
(Those Kics are just 3mm)
You will need spacers that are hub centric
#3900
I recommend extended studs for the front and a 10mm hubcentric spacer. Like he said the lugsare to hold the wheel not to let it sit and ride on the studs.
