Tire / Wheel Fitment Questions
Old Oct 25, 2004, 11:23 AM
  #61
GokuSSj4's Avatar
Enkies RPF1 17x8.5 +40 off set fit with no problems
as Gramlights 57s 17x8.5+40 off set as well
you can run 235/45/17 with no issues
currently have 255/40/17's RA it barly clears the rear fenders w/ JIC's tune by John Mueller.
now just to be on the safe side both rear fenders are roll (enough clearance.)
rolled fender
non rolled fender
Old Nov 2, 2004, 11:18 PM
  #62
PunoEvo1337's Avatar
TSW thruxton wheels
I just bought some 18x8 TSW thruxton wheels. I am not sure of the offset that they gave me (bad move on my part), but they are riding too wide and hitting the fender on big bumps and fast turns. Just wanted to know if anyone knew the proper offset needed for these rims or if there is something that I can do (other than modifying the body with a fender roll). Someone suggested getting smaller tires might solve the problem, but if anyone has any suggestions it would be very appreciated.
peace
Old Nov 5, 2004, 08:39 AM
  #63
MIevo8MR's Avatar
Question Motegi MR7 17x7
Neal,
Will the Motegi MR7 17x7s fit my Evo 8 MR? I have a set of these rims that I used on my old Pontiac Sunbird. I plan to use them for my winter wheels. If they do fit, can you recommend a good all season tire and size that I can use.
offset: +40
bolt circle: 5x100 & 5x4.5
weight: 24.5 lbs.
Old Nov 5, 2004, 08:45 AM
  #64
Neal@tirerack's Avatar
Dosen't look like the bolt pattern is the same. EVO has a 5-114 and those wheels are 5-100. The Conti Extreme Contact would be the best all season performer. A fav of most EVO owners
Old Nov 5, 2004, 09:54 AM
  #65
MIevo8MR's Avatar
Lightbulb
But it has 2 bolt patterns
1) 5x100
2) 5x4.5 ---> 4.5"=114mm ---> 5x114
Is the +40 offset ok?
Old Nov 5, 2004, 10:54 AM
  #66
Ahh didn't see the multi bolt pattern reference. Since I don't carry that brand, I really cant say for sure if its a good fit. The offset might be ok, but the center bore, lug seat, wheel style may all interfere with fitment. If you have the wheel and the EVO just bolt it up and see if it will work. I would still contact a Motegi dealer for best results.
Old Nov 5, 2004, 11:16 AM
  #67
jbrennen's Avatar
In general, a 17x7 wheel with 40mm offset will have the outer edge of the rim sitting 14.7mm further inboard from the stock wheel.
There is nowhere near 14.7mm of extra clearance between the stock wheels and the front calipers. Unless the Motegi 17x7 wheels are a very unusual design, they will almost certainly not fit over the front calipers.
Old Nov 22, 2004, 08:29 PM
  #68
Evo7363's Avatar
Need Help, wondering if the 18x8 ADVAN KREUZER X W/ DUNLOP SP SPORT FM901 TIRES with P.C.D of 114.3 and the offset 45mm will fit in my 2003 Evo.
Old Nov 22, 2004, 08:31 PM
  #69
timzcat's Avatar
I believe they will. Talk to Gruppe-S.
Cal tried them on his car and he said they didn't look right and he took them off.
I was once interested in them but I talked to Cal.
Old Nov 22, 2004, 08:38 PM
  #70
Gruppe-S's Avatar
Hello, Advan Kreuzer X in proper EVO fitment would be 18x8 5x114.3 +30mm offset. Or you can go with 18x9 5x114.3 +38mm offset as well.
ETA will be 4-6 weeks upon ordering.
Thanks
Cal
p.s Thanks Timzcat
4bangn (Mar 30, 2020)
Old Nov 23, 2004, 12:49 PM
  #71
Willie's Avatar
So....
What about 18 x 9 CE28N with +35 offet all arround with 245-40-18 ties ? will they rub or have to roll fender ?
Willie
Old Nov 23, 2004, 12:55 PM
  #72
Gruppe-S's Avatar
18x9 w/ +35 offset will work. No need to roll fenders.
Old Nov 30, 2004, 06:58 AM
  #73
ghettoracer's Avatar
Location: land of happy motoring, sunny northern california
Tires are going to be Toyo RA1 235/40/17
we're thinking of Enkei RPF1 17x9 et35 (15.9 lbs)it ought to fit with the above tires with out fender rolling.
What do you guys think of the next size up RPF1 17x9.5 et38 (16.5 lbs) I'm thinking it should fit too. Weight difference is just 0.6 lbs and 1/2" width could be useful...
I saw that hardcore autox guy use 18x10 and 285 width tires. Does anybody know what offset they use? Thanks.
Old Dec 1, 2004, 10:13 AM
  #74
GokuSSj4's Avatar
if you plan to run 235's RA1 on the RPF1
i would go with 17x8.5 +40off set , i have those and fit fine with no problems, ou can even upgrade to 255/40/17s RA1 later on (what i currently have )
Old Dec 13, 2004, 03:35 PM
  #75
Kaane's Avatar
will 18x9 TE37's 40mm offset fit without rubbing? What tire size would fit best?
Quick Reply: Tire / Wheel Fitment Questions
