SCCA BSP modifications
Old May 17, 2011 | 02:45 PM
chu's Avatar
chu
^^^ Now I'm not sure of how the process works, but I believe that if someone has a reason to believe you have an illegal mod, tech is allowed to tear your car apart.
Old May 17, 2011 | 04:54 PM
griceiv's Avatar
Originally Posted by chrisw
your synapse DV put you in Street mod,
nothing wrong with the DV or ported EM/IM/O2. Ported turbo hotside is illegal as is the JDM rear bumper and depending on what you had to do to fit the Ebay intercooler it may also be illegal. Depends on what OSGiken part you have, their clutches aren't bsp legal but their diffs are.
To the OP, Diffs are able to be replaced with anything as long as you keep the stock final drive ratio and it's not electronically controlled. RCK is illegal but really only because you have to install different tie rod ends.
Old May 17, 2011 | 10:32 PM
grahamab's Avatar
I think the JDM rear also bumps him clean out of SM as there really hasn't been a method demonstrated for keeping the rear crash beam while only removing less than 1lb of material to do so.
Old May 18, 2011 | 01:38 AM
RevMoto's Avatar
I have a tubular crash beam from evasive motorsprts. They didn't comment on the jdm rear and all of the evos had them.
Old May 18, 2011 | 06:26 AM
grillpt's Avatar
JDM rear would be considered an aero mod and is illegal in BSP.
Old May 18, 2011 | 07:16 AM
nollij's Avatar
What about a Beatrush under-engine cover? I am guessing that that would put the car in Street Modified as well, correct?
These rules sure are nit picky... I am starting to think I should just go to Street Modified to not have to deal with all the details.
Old May 18, 2011 | 07:38 AM
chu's Avatar
chu
This is the case for many of us, myself included, who starts to modify our cars to our liking, and than get into racing. We suddenly come to the realization the mods we have puts us in a class where we're usually not competitive at all becasue everyone else has taking full advantage of the rules, and we are left to eat their dust!
Old May 18, 2011 | 09:16 AM
RevMoto's Avatar
Why are we not competitive in SM?
Old May 18, 2011 | 09:28 AM
evremonde's Avatar
Another episode of "deep thoughts with chu".
Because if your in SM due to a jdm rear or ported hot-side you are probably under-prepped for the class. Locally most cars in SM are there for this reason, so it is typically a very full and competitive class.
Old May 18, 2011 | 09:51 AM
Dallas J's Avatar
Veteran: Army
SM often has 1 or 2 semi-prepped cars that will be tough to beat where as in BSP if you have some suspension goodies and DOT slicks then you stand a chance of not looking embarrassed. Though if your club is like the NW then almost all SP classes are faster than SM.
Me personally, I like to compete in PAX. SM is NOT the place for that.
Old May 18, 2011 | 10:04 AM
RevMoto's Avatar
The tech was kinda clueless on the classes and just put me in sm. It wasn't because of my jdm rear or ported parts. Besides slicks I dont see how I am under-prepped. Even after reading the scca rule book I still can't see where the jdm rear with a modified crash beam makes my car ineligible for bsp.
Old May 18, 2011 | 10:06 AM
chu's Avatar
chu
Yeah, I get pretty technical!
Old May 18, 2011 | 10:18 AM
grillpt's Avatar
I know myself (and Chu) aren't simply because we don't run R-Comps. In SM you need to be running 285-30-18 Hoosiers if you want to compete seriously.
Old May 18, 2011 | 10:53 AM
RevMoto's Avatar
the same disadvantage can be said about bsp.
Old May 18, 2011 | 11:44 AM
nollij's Avatar
Considering that you are in the Northwest, what tires do you run? I was thinking about 275/35/18 Star Specs as they would still work great in the rain but they are 5 lbs heavier per wheel than the Hankook RS-3s. They are both about the same price and these tires will also be used for daily driving (no slicks).
