bumpy braking/slow down?
Old May 29, 2011 | 10:38 AM
taylorgang's Avatar
when I'm braking I get this bumpy motion like the brakes are on and off for milliseconds at a time. I heard it could be warped rotors...
I bought the car from a dealership about 2 months ago and they said that if anything were wrong with the brakes/if the brakes were worn down they would have replaced them
what generally causes this to happen? and how long does it take?
P.S. I don't track my evo
Old May 29, 2011 | 11:38 AM
bryanf's Avatar
The rotors might need to be resurfaced.
Bryan
Old May 29, 2011 | 11:42 AM
Nashou66's Avatar
I have the same issue right now on mine. Been like this for a few months, when i asked a local mechanic that comes into my diner he said it is in fact a warped rotor and you only feel it under the slow down portion of breaking when you have less pressure on the pads. It makes the Anti lock break system think the wheels are slipping thus making the system go into action.
Athanasios
Old May 29, 2011 | 11:53 AM
4whlbst's Avatar
It doesn't cause abs to go off. The abs actuates off of wheel speed sensors not the rotors. Your problem is overheating your front rotors, usually from very heavy braking then resting on the brake pedal for a period of time causin the rotor to overheat or very light braking for long periods of times, say if u rest your foot on the pedal. Warping of the rotors is sometimes due to pad material but usually due to driver braking habits. Try to revaluate the way u stop to prevent this in the future. Also pad selection helps, try ferodo ds2500, I've personally ha very good luck with those pads. There are others that are good, just search the forums. Now to eleviate your problem at hand, yes you will need to machine your rotors flat again, but get them measured as if they are getting thin you will need to replace them. Hope that helps.
Old May 29, 2011 | 12:04 PM
Smike's Avatar
"Warped" rotors is pad material transfer.
Re-surface rotors. Check pad type and life. If low quality or racing pad (out of temp usage range) it will deposit material to the rotor surface.
Old May 29, 2011 | 12:42 PM
igo4bmx's Avatar
agreed
i had this problem with a set of centric pads- replaced them with racing brake pads and now the shaking stopped.
Old May 30, 2011 | 10:56 AM
Ruthless.'s Avatar
resurface rotors
Old May 30, 2011 | 01:41 PM
taylorgang's Avatar
thanks! I'm gonna get my rotors checked out and hopefully resurfaced soon... it happened to me in my Z too but I had warranty so it was free plus the rotors on the Z needed resurfacing because of something else, so in that case it wasnt my braking hahaha.
thanks for the replies!
Old Jun 1, 2011 | 11:37 AM
jenyeart's Avatar
yeah i've heard of this happening. Needs a break job
jrmck
Jul 31, 2015 10:45 PM
OZR_Lancer
Jul 4, 2014 01:38 PM
Hopleaf
Lancer Troubleshooting
12
Feb 6, 2012 05:40 PM
JKav
32
Jan 13, 2011 02:12 PM
dman9271
24
Nov 29, 2007 03:27 PM
