to mount fitted, now a new problem...help please
Old Jun 16, 2011 | 01:08 AM
Wayne'o's Avatar
Well the car was knocking when turning right, turns out it was the nearside top mount and has now been fixed, new top mount and drop links,
However a new problem has occurred, when driving at around 30 there is a loud rumbling sound, bit like a wheel bearing,
it happens when in a straight line or turning left but when I turn left it disappears.... I'm confused has anyone came across this?
Also I read somewhere you can put some extra grease into the top mout bearing?
Old Jun 16, 2011 | 02:27 AM
Smike's Avatar
Saw the wheel left and right (slightly) as you go straight. If the noise disappears then I would lean towards a failing wheel bearing (hub assembly in the Evo).
