Highest/lowest offset for Evo 5 and 6.
Old Aug 12, 2011 | 01:10 AM
alanranch's Avatar
Good day members I was just wondering the highest offset you can put on an evo V and 6 thatll clear brembo brakes. If you have pictures hope you can post them. Thanks
Btw I was able to use Rota GK-R's 18x9 w/ an offset 25. on stock suspension whenever the car dips itll hit the rear flares. Tires that I mounted was 235/40-18 assymetrics. After awhile I changed back to 17s since my rear flares got beat up. I installed coilovers now and im just wondering if itll solve the problem coz my evo V looks so much better w/ 18s. cheers
Old Aug 12, 2011 | 05:26 PM
Vivid Racing's Avatar
Depends on the spring rate. Chances are, yes, you'll be ok.
Old Aug 14, 2011 | 09:12 AM
VROOOM's Avatar
+35 and below should clear brembos, depending on wheel design. As long as you shave and roll your guards, it'll clear anything as low as +15. But that will of course stick out of the guards a fair bit.
You could shave the rear guards with a Dremel and roll the front guards. Also, run stiff suspension with abit more aggressive camber.
e_kobz
24
Jun 2, 2014 12:17 PM
zboost
Apr 9, 2014 08:43 AM
RenleyX
32
Apr 19, 2012 09:35 AM
jcrb
Oct 3, 2010 02:41 PM
booster9
13
Feb 10, 2010 03:41 PM
