Volk Gram Lights 57F
Old Jan 2, 2004 | 09:22 AM
Flames-666's Avatar
Just received my 57F's, 17x8.5 +30, Bronze
However, I'm confused about the issue of being "hubcentric"...
What does this mean, and do I need "centering rings"? - will Discount Tire have this when I go to have them installed?
Thanks in advance - Rob
Old Jan 2, 2004 | 09:55 AM
ChrisS.'s Avatar
"Hubcentric rings are designed to fill in the gap between the hub of the car and the center bore of the wheel. Most wheel manufacturers design their wheels with a center bore large enough to fit on most cars. Therefore, since wheel manufactures make their center bore large enough to fit most cars, most wheel fitments have a gap between the hub and the center bore. This gap usually doesn't allow for the wheel to fit hubcentric but rather lugcentric which causes vibration. Therefore, to fill the gap and ensure the fitment is hubcentric, hub rings are used."
Got that from a website....not sure if it answers your question though....
Old Jan 2, 2004 | 09:58 AM
ChrisS.'s Avatar
www.justforwheels.com
Old Jan 2, 2004 | 01:38 PM
gonzo's Avatar
Hey, I just learned something!
Old Jan 2, 2004 | 02:09 PM
broeli's Avatar
Where did you get them...Dicount Tire? How much were they?
Old Jan 3, 2004 | 04:24 PM
ACM's Avatar
ACM
Most adaptor rings are plastic, or occasionally soft aluminium; were the seating location chosen by these rings to disagree with that determined by the conical/acorn wheel nuts almost universally employed, the rings would lose out in a heartbeat.
Charles
Old Jan 4, 2004 | 12:33 PM
Flames-666's Avatar
Check it out - a killer deal indeed
https://www.evolutionm.net/forums/sh...&highlight=57f
turboed350z
For Sale - Wheels / Tires
27
Aug 15, 2016 12:06 PM
turboed350z
25
Aug 15, 2016 12:03 PM
nsheasley
May 5, 2015 01:37 PM
dasilveira
Jul 20, 2011 08:53 AM
diiirk@AwdMotorsports
Jan 6, 2008 02:49 PM
