Dunlop Direzza's caused oversteer??
Old Nov 7, 2011 | 05:56 PM
jstride's Avatar
Installed some 255/75 Dunlop Direzza's on the Evo 9 several months ago and now it's oversteering and is noticeably more difficult to control at high speed, especially when cornering. I dropped the rear tire PSI to 28 to see if it would "bite better". A bit of improvement but not much.
Anyone else have this issue? Could it be a strut going bad combo or something?
How did you tune or adjust to overcome instability or traction when cornering?
Thanks Gents!
Old Nov 7, 2011 | 06:01 PM
Dallas J's Avatar
Veteran: Army
Instability is generally a sign of a bad alignment. Have changed ride height since your last alignment?
What are your other mods? If a big rear adjustable bar, try setting it softer.
Old Nov 8, 2011 | 04:09 AM
Smike's Avatar
That ^
You mean 255/45? And I would not drop the pressure to that low. You're front tires will be rolling over themselves.
Old Nov 8, 2011 | 08:15 AM
Neal@tirerack's Avatar
Try moving the tires around to see if the issue remains or moves to a different part of the car where you put the tires.
Old Nov 8, 2011 | 09:04 AM
Smike's Avatar
Crux here is that you installed the tires several months ago. Now you have a handling issue. Why do you think the tires are the root cause? Name all the parts that relate to handling
MisUnderStood
For Sale - Wheels / Tires
19
Jan 1, 2017 08:06 AM
Mivec0424
22
Jun 8, 2012 05:23 AM
Solo II Evo
14
Apr 29, 2010 06:15 PM
turbodreamz21
13
Feb 23, 2010 11:19 AM
tougetuned
24
Apr 16, 2009 04:55 PM
