-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   Dunlop Direzza's caused oversteer?? (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/582685-dunlop-direzzas-caused-oversteer.html)
jstride Nov 7, 2011 05:56 PM
Installed some 255/75 Dunlop Direzza's on the Evo 9 several months ago and now it's oversteering and is noticeably more difficult to control at high speed, especially when cornering. I dropped the rear tire PSI to 28 to see if it would "bite better". A bit of improvement but not much.
Anyone else have this issue? Could it be a strut going bad combo or something?
How did you tune or adjust to overcome instability or traction when cornering?
Thanks Gents!
Dallas J Nov 7, 2011 06:01 PM
Instability is generally a sign of a bad alignment. Have changed ride height since your last alignment?
What are your other mods? If a big rear adjustable bar, try setting it softer.
Smike Nov 8, 2011 04:09 AM
That ^
You mean 255/45? And I would not drop the pressure to that low. You're front tires will be rolling over themselves.
Neal@tirerack Nov 8, 2011 08:15 AM
Try moving the tires around to see if the issue remains or moves to a different part of the car where you put the tires.
Smike Nov 8, 2011 09:04 AM
Crux here is that you installed the tires several months ago. Now you have a handling issue. Why do you think the tires are the root cause? Name all the parts that relate to handling :)
