Caliper Piston Removal Question
Old Dec 14, 2011 | 09:51 PM
sna08's Avatar
I'm getting ready to replace the front caliper seals on my evo9. Got it from the subaru site everyone recommended for the brembo seals. I know I can get it out with an air compressor but since I don't have one what other options do I have to remove them?
1. Can I remove caliper off of rotor and pump the brake pedal to "pop" them out?
OR
2. Will a tire/air compressor work if I can somehow get it to fit properly?
Old Dec 15, 2011 | 05:14 AM
blknblubkrdude's Avatar
Option 1 will definitely work, but you will create a gigantic mess and most likely introduce air into a lot more parts of your brake system.
Option 2 is your best bet. It will hardly take any pressure at all to get them to pop out.
Make sure to wrap the caliper with a rag or towel to prevent brake fluid splatter.
Good luck!
Old Dec 15, 2011 | 05:12 PM
flyingscot's Avatar
yeah using compressed air and a blow nozzle is by far the best way to remove them,surely you have a friend that owns a compressor
Old Dec 15, 2011 | 07:07 PM
sna08's Avatar
Yes I do have a friend who has one but our schedule differs and it needed to be done ASAP... When I hear compressor I always thought of the big ones never thought about using tire compressor which I just did and with the right adaptor got it to fit properly... Though only one came out... The others I had to safely pry off
Old Dec 15, 2011 | 07:14 PM
4RETECH's Avatar
Trick is to use a block of wood that is the right thickness to get all the pistons to pop out. Also, I'm surprised. No one said grease gun. Add a grease fitting and pump away. It's a mess but gets it done.
Old Dec 15, 2011 | 07:40 PM
sna08's Avatar
I was thinking of popping all fours but wasnt sure if it'll do harm or not... maybe when i do the rears i'll use a thinner block... i used a 2x4
jingalalahoe
Sep 9, 2016 12:44 AM
turbotaloon95
24
Jul 28, 2015 07:47 PM
Wapoosh
Apr 4, 2015 05:36 AM
SparkTech
26
Dec 9, 2011 09:10 AM
bandwagon
15
Apr 11, 2007 10:12 AM
