Anyone have Ohlins DFV Owner's manual and installation/set-up guide?
Just picked these up used and didn't get any of the booklets etc. Does anyone know where I can find them online? I searched high and low and can only find the manuals for the motorcycle stuff.
Hoping someone has all the booklets as I am going to be installing them today. Thanks!
I do, but unless you speak Japanese it'll be as useless to you as it is to me. The install is straight forward and you'll want to get your car corner balanced. Adjust settings as desired.
Deeman please post them. There is very little difference between the DFV (2007-2010 production) and the new R&T. All the dimensions for the install are the same.
Ok so slight problem with that....its not at my current location
. You'd have to wait 2 weeks before I can get them and post them. I'm 90% sure I don't have it on me right now. What exactly did you want to know anyways? I've disassembled/reassembled installed/uninstalled my c/o enough times. Maybe I can help.
I got a few questions:
1) What is the torque setting for the allen head bolts that clamp the front height adjuster/bracket?
2) What is the torque settings for the top nuts for the front and for the rear? And how are you supposed to use a torque wrench on it when you have to have an allen head key in there?
3) Preload on the spring is supposed to be added by turning the bottom collar rather than using the top nut correct? Because then you are adding spring preload without shortening the stroke of the piston.
4) What is the torque setting for the top camber plate allen head bolts?
Don't remember, but I know its a low number. Something in the 15lb/ftish region.
There is a range that you can have them in. I chose the middle of the range. And my front I torqued to 29lb/ft and the rear to 20ishlb/ft. You need to use a crow's foot adapter to use a torque wrench. Or if you trust your hands then just guesstimate it....its not that high.
The manual specifies 2mm of spring compression using the bottom collar to compress the spring. So it goes from 100mm to 98mm. Thats the factory preload.
Again, its low. But I don't remember exactly. I'd guess something like 20 to 35lb/ft.
https://www.ohlins.eu/download/db/Oh...--00000142.pdf
I know this is an old thread but just found this and am posting for posterity.
There are lots of difference between the DFV and the R&T. I dont know why they switched named 2 times, but there is an old R&T which has fixed body length and the newest version which seems to be a cost reduction of the DFV. In my case, I had to figure out how to make the various Ohlin parts work with all of them, and also the Flag version (double adjustable).
WTB[SouthEast]: 2003 Owner's Manual!
wazmunstr
For Sale - Miscellaneous Automotive
Jul 23, 2016 02:52 PM
FS[Pacific NW]: unused/ new WORK 11r 18x9.5+20 WMB PORTLAND *Free shipping*
06h
For Sale - Wheels / Tires
Apr 15, 2016 06:16 PM
FS[Northeast]: Valentine one radar detector
dookgvr4
Jan 14, 2016 07:06 PM
rage mang
Oct 25, 2015 04:43 AM
Thanks guys!
