need advice on tires pls
Conti DW
amazing in the wet, decent dry grip, i have over 20k on my tires & looks good @ 1.8*F/1.3*R camber @ Zero toe F/R
side walls are a bit compliant, but if your in NY, the roads are not the smoothest anyways, so these will aid in the DD part of things.
I am testing a set of DW right now too. Not a bad tire at all. GY Asy 2 is in the same market it it. Driven V12s too. If really a strict DD - I'd rock it for the price they are at.
how are the dw's compared to the star specs? i imagine better in the wet and not as good on dry surfaces? totally different categories?
Don't hold a candle to the Z1*s really (wet or dry). Different class of tires. Z1* are extreme "AX specials". DW are summer tires for wide use.
I've AX'd and tracked the Z1 and Z1* in the wet. Work very well.
RS3s in wet = scary.
XS = scary.
Another tire to look into is the Goodyear Asymmetric 2. I am run that as my race tire for TT my SVTF this season. Most current tire in terms of technology and compounds. OEM on Porsche as well.
XS = scary.
What size would you run for the EVO8 BBS MR rims? TireRack only listed 235-45-17 and 245-40-17. I'm coming from the 255-40-17 Star specs which are worn out now. I'm leaning towards the 235-45-17 97Y version ( higher load capacity ) I do like that the weight is only 24 lbs on the Goodyears compared to the 28 lbs on the Starspecs ( 235/45 vs 255/40 )
Any idea of how long the softer compound on the Goodyears will last in relation to the StarSpecs?
Reason Im asking is the 255-40 Star specs are now $180 each vs the $150 for the Goodyears on TireRack and despite the really fantastic handling of the Star specs, its a stretch with money right now.
Suspension is MR Bilstein plus Swift Spec-R's, bushings + RSB.
Milburn
