wheel spacer suggestions
Old Mar 8, 2012 | 03:26 PM
sdfontanini's Avatar
have rota torque 18x8 with 30mm offset, what spacers would you suggest?
Old Mar 9, 2012 | 09:50 AM
54 views and no response, anyone ?
Old Mar 9, 2012 | 10:28 AM
sujinX's Avatar
does the wheels not fit? if it doesnt mock it up and see how much spacing is needed. or look here https://www.evolutionm.net/forums/ev...ly-thread.html
your question is kinda broad. if it doesnt fit, do the above and measure spacing required and get the spacer.
if you want it to sit wide then thats up to your preference.
Old Mar 9, 2012 | 10:33 AM
Dallas J's Avatar
Veteran: Army
Why do you think you need spacers. Stock wheels are 17x8 +38.. Those already are 8mm further out. Spacer if you need to clear calipers up front or a bit more flush but that is going to be completely dependent on the camber you run, rolled fenders, tire width, etc..
Old Mar 9, 2012 | 10:57 AM
wheels fit fine, just want a more aggressive look... running 235 45 18 tires, car is dropped and my camber is set at stock -1 I believe
here's a pic
kingRob757
Mar 16, 2016 08:17 AM
Jonno99
Sep 10, 2015 11:45 PM
coloradoboost
May 14, 2015 07:26 AM
eusgen
Jan 19, 2013 09:05 AM
ToddMcF2002
Dec 28, 2009 05:06 PM
