Work Meister s1 3p
Work Meister s1 3p
Hey guys, I have this posted in the All Wheel/Tire fitment thread but no one has answered me yet so i thought id just put it here.
Im thinking about getting a square set up of work meisters s1 3p in 18x9.5 + 23,24, or 29 (not too sure what offset is needed to clear the brembos). Not sure of the modification that would be needed, and if the stock brembos would fit with this design. I also forgot to mention that this will be a daily driver, it will never see the track, and will ride on stock blistens and on swift springs.
Now i did try to look for the answer but the ones i found weren't in the sizes i wanted or were to radical for for : The Ultimate Aggressive Wheel Thread... (post 5985), http://www.iputinwork.com/?p=351 and http://www.rimtuck.com/setup/view/783
Thanks for your time
I have the Meister M1R's in 18X9.5 +20 and they clear the Brembo's.......don't stick out like they are Hella flush or anything like that. You will need to roll and pull your fenders.
Doesn't matter what offset to clear the brembos all depends on what wheel disk you choose.A disk,O disk,L disk,R disk,R disk. L,R & T disk will clear the front brembos with the rears you can probably run any of the disk but O disk.
I had Meister before and they were all O disk to clear the brembo. Mine was 18x9.5 all around +12.
This is not about how much offset to clear the brembo on Meister its about which type of disk you have.
Alright thanks guys, that helped a lot. I had no idea. Thanks again
Pink godzila: do you have any pictures of your evo with the meisters by any chance?
You sure about that O disk has the least amount of clearance for bbk. & is more design for offering the most amount of lip
57ING
Sep 4, 2013 05:48 PM
RavSpec
Evo 'For Sale' Wheels / Tires
58
Mar 20, 2013 10:26 PM
RavSpec
Jan 15, 2013 07:40 PM
Touge Factory
Jan 10, 2012 03:12 AM
