Rear Sway Bar Install
Old Apr 26, 2012 | 03:55 AM
catman78's Avatar
Hi all,
Installing a Swift sb on my 8.
I've seen a one thread and a few PDF's(Hotchkis, Perrin) regarding procedure.
I'm using stock mounts and end links.
Do I need to drop muffler or remove lower control arm to snake in bar?
Driveway job, no lift.
Please chime in if you've done this install.
Thanks
Old Apr 26, 2012 | 04:04 AM
meckert's Avatar
no, its simple and straight forward, wont take an hr.
Old Apr 26, 2012 | 04:31 AM
wariosport's Avatar
Veteran: Army
Originally Posted by catman78
Hi all,
Thanks
Some people have gotten away with not having to drop the control arm. I dropped it and it made it super easy for me.
Old Apr 26, 2012 | 09:44 AM
Jim3142's Avatar
You're going to need to drop the muffler. Some people, I think, have gotten away with not dropping the lower control arm and were able to wiggle the bar in, but if you can't get it in within 15 minutes, then just drop the lower control arm and spare yourself the 2 hours that I wasted
Old Apr 30, 2012 | 09:13 PM
arem's Avatar
Sounds about right.
Old Apr 30, 2012 | 10:53 PM
sujinX's Avatar
i just dropped the muffler, no lift here. i tried to snake it with muffler on, but that was a bad idea.
the BIG part is, spray some pb blaster on the endlinks, and before u try to do anything, see if u can break them loose before unbolting the sway bar. 1 of mine was seized and i had to order another set.
Old Apr 30, 2012 | 11:03 PM
XcreatonX's Avatar
I just installed mine today. I got the old one out with just dropping the exhaust. Went to put the new one in and it was close. Ended up dropping the driver sided control arm and it slid right in. I got sent the wrong endlinks so I'm waiting on those but it seems to be rubbing on the subframe. Anyone else have that issue?
Old Apr 30, 2012 | 11:13 PM
EvoDan2004's Avatar
you should not have to remove the exhaust but if it makes your job easier then remove it. you can also use the stock end links. basically remove the stock sway bar and depending on what sway bar you bought then just follow the setup directions and bolt it up.
Old May 1, 2012 | 12:10 AM
headlock's Avatar
drop the muffler. you can get it in without dropping the LCA but it's probably just easier to do it straight up rather than waste a bunch of time trying and then having to do it anyway.
michael2014
Feb 2, 2016 04:40 PM
Fuchsig
Jan 11, 2015 03:20 PM
evoiao
Sep 7, 2013 02:38 PM
nx302stang
Jan 30, 2011 11:32 PM
psychlancer
04-06 Lancer Ralliart How To Requests / Questions / Tips
Sep 14, 2005 03:07 PM
