OTS Ohlins R/T DFV valving
This is good news. Sounds like a revalve isn't absolutely required.
I am running 255-40-17 BFG R1S tires on 17x9 rims. They are as wide as a 275 hoosier though and considered a cheater tire.
Thanks for the info fellas. Now I need to find some 12k springs.
Stroke is shorter, but the spring size is the same.
^Oh you're a genius
Jeff- let us know what you decide to go with and please share your findings. For those that replaced their springs, did you go with a particular brand such as Swift, Eibach, Hypercoil? I know lots swear by swift but I question whether they are actually better than the aforementioned brands...
I got to thinking last night .... if its only a couple hundred bucks for a revalve then that is what I'm going to do. No sense in taking shortcuts on one of the most important items in the parts list especially if it could shorten the lifespan. I'm attempting to gather quotes for the revalve and will likely get springs directly from Ohlins.
Getting the rears set up for 12k with the possibility of a 14k future sets the entire car up for future spring rate increases. The rear 12k could go to the front and I could add 14k to the rear if desired. I'd rather entire system be dialed in perfectly.
^Oh you're a genius
im running the old gerard spec ohlins (r/t's i believe). i think they can handle 10k/12k i was told.
I'm running 600/700 lb Hyperco's from here http://store01.prostores.com/servlet...ngs:8in+Length "The Shock Shop" Fast shipping, $54 per spring.
Im not an engineer nor do I know a lot about the characteristics of springs however so Im merely thinking out loud here but what really makes up a spring? What makes certain springs better than others? The only factors that come into my head are the following:
-Consistency
-Durability
-Weight
Do we know who makes the springs for Ohlins? I know that not all springs are created equal but I am not a professional so I do not demand the absolute best. If I can spend 1/2 as much on springs going with Hypercoils vs. Swifts I can then allocate that savings towards a revalve instead.
-Consistency
-Durability
-Weight
-Consistency
-Durability
-Weight
-Consistency
-Durability
-Weight
see below:
Swift's R & D team created a material, called H5S.TW. This advanced alloy
is stronger then regular silicone chrome material. Swift could make the spring wire thinner, and could wind the springs with fewer coils, which greatly decreased weight while dramatically increasing available stroke.
^Thanks, that is the excerpt that I read in the past. My question remains though as to how much of that is the truth vs. marketing hype. I dont mean to sound like a skeptic but I would love to see some cold hard facts. There must be some independent tests floating around the web. When I have some time I will see what I can come up with...
spring rate consistency is important too:
http://www.northamericanmotoring.com...gs-dynoed.html
ive read a few mentions of them having better "frequency" (which i believe is basically reaction to things like bumps) but never found any hard data on that.
