Would you CUT the BUMP STOP?
I am not 100% sure, but I did not cut the front stops at first, and it seemed stiffer then. After I cut 1/2 of the stops off, the front suspension seems to be freeier.
I guess you have the S-Techs? They drop really nice.
did you notice your car lower more in front after cutting it? Did you had any cracking noise (Iam geting some stupid crackin noise when i go slow and it comes to turn left or right or if i go reverse (what should i be more carefull about the springs in front when installing) iam thinking to re-check front springs and cut the bump stop.
