Tire Noob (2). Help
Tire Noob (2). Help
I have the stock setup at the moment... on my 2.0 de...
Wheel Width:6.5Tire Profile:60Tire Width:205Tire Diameter:
16.0Front tires: 205/60HR16.0Rear tires: 205/60HR16.0
WTF does all of this mean!?!?!
I need a breakdown, i need pictures of nice setups, i need tips and ideas..
Here is the breakdown of what i would like ----- 17 or 18in rims... bronze preferrably.. I would like low profile tires but wider stance ... i don't want to have to install anything else so im staying away from camber kits and whatnot... (even though the car is fatter at the back and dumped it would look nice without looking so straight, ya kno?)
Thanks for reading.. looking forward to some good ideas and what type of numbers i should be looking for!
PS i like some of the things iv seen at Tire Rack.com, but i dont know if i order a wheel + tire package, if i can change the tire sizes.. bad enough i dont even know what the numbers mean.......
You can see the complete list of wheels we have available for your vehicle at: http://www.tirerack.com/a.jsp?a=EL1&...eels/index.jsp
Simply enter the specifics on your vehicle’s make, model and year, and my site will display every option we have available that fits your vehicle properly. It will also display the correct tire size that fits both car and wheel properly. If there is a size aside from what we list online you would rather use, call me direct and I can assemble the package manually via phone.
Thanks Neil for the quick reply,
My question was more geared to getting a set of tires that doesn't look or sit as the stock set up does.. i want something wider and thinner.. like a low pro but a fatter(wider) tire.. to give some dimesion to the wheel and when you look at the car overall..
I know that the automatic setup that is calculated and provided on your site is ideal.. but again im looking to change away from the typical look.. plus i wanted to learn what the numbers meant.. if ya wanna get back at me .. im all ears..
Thanks
Thanks
TheChampiYon
Nov 10, 2015 05:48 PM
JMusto0223
14
Sep 10, 2015 10:49 AM
RAbo
Jul 2, 2012 01:37 PM
Labrie
Nov 5, 2011 05:24 AM
Sparx123
Oct 7, 2009 04:09 PM
