Wheel offset?
there are a ton factors to offset....it all depends on wheel type. 0 offset theoretically would be the farthest the rim can sit off the hub. so the bigger number you go would would pull the rim closer towards the hub, if that makes any sense to you.
Mess around w/this calculator which will help you gain some understanding how offset affects wheel fitment
http://www.rimsntires.com/specs.jsp
XIRMOVE
Oct 28, 2007 01:50 PM
