KW rear spring size
KW rear spring size
Hey guys,
Im about to pick up a used set of KW V3 coilovers for my 9. Spring rates are front- 9Kg, rear- 6Kg with helper springs.
I want to swap the rears for 10 or 11Kg.
Question- What size are rear KW springs??
I did some research but didnt find a definitive answer. Some say 60mm, some 65mm.
Are they 6,7 or 8 inches tall? And any recommendations on the brand- Swift, Eibach?
Thanks
Thanks
Hey guys,
Thanks
Thanks
Length should take you about a minute to figure out if you have a measuring take and a jack.
One thing to look at though, if you want to go lower than you are and are already at the bottom of adjustment go with a shorter spring cause the stiffer spring at the same perch setting will sit the car higher.
Anyone knows if 10Kg would work good on stock KW rears? Someone mentioned that 11Kg is close to the limit of the shock.
Hiboost
75
Dec 4, 2019 05:09 PM
guyver858
Dec 31, 2016 04:22 PM
LCS
42
Jun 17, 2016 12:01 AM
Nasty Evolution
Feb 2, 2010 09:42 AM
staffe
Jun 20, 2009 11:04 AM
