evo 8 brakes
Old Jan 27, 2004 | 08:13 PM
olosports's Avatar
evo 8 brakes
can anyone tell me how i may aquire full specifacations on the evo 8 calipers? or if someone could send them to me it would be great!
Old Jan 27, 2004 | 08:17 PM
blonde's Avatar
what exactly do you want to know? i have the shop manual here so i can find it for you.
Old Jan 27, 2004 | 08:19 PM
Chris in HB's Avatar
Wheels and Brakes
The Lancer Evolution is shod with lightweight, 17-inch, one-piece aluminum wheels that help minimize unsprung weight. The wheels were developed exclusively for the Lancer Evolution by Enkei(R) and are wrapped with 235/45R17 Yokohama ADVAN A046 tires. The rubber compound and tread pattern used in the construction of these tires was designed specifically for the Lancer Evolution to help improve grip at high g-force loads and elevate the vehicle's cornering limits. Brakes are large Brembo(R) discs with aluminum opposed calipers, combined with EBD (Electronic Brake Distribution) and Sport ABS to help ensure stability (ABS is not available on the RS trim). The front brakes utilize a large ventilated 12.65-inch (320 mm) rotor and strong four-piston calipers, while the rear uses a two-piston caliper and solid 11.8-inch (300 mm) rotor design.
This competition-oriented Brembo(R) braking system provides incredible stopping power to match the vehicle's drivetrain capability. The EBD system (standard on the Lancer Evolution, not available on the Evolution RS) utilizes computer control to help ensure optimal distribution of braking forces. In addition, this system governs rear brake forces to help reduce temperature build-up in the front brakes under hard braking conditions. Independent control of the left and right rear brakes also helps the vehicle realize better braking balance during cornering.
The Lancer Evolution's Sport ABS offers four-wheel independent control to help optimize the braking actions from each wheel and help maintain control and stability. The system utilizes a steering wheel angle sensor, longitudinal and lateral G-sensors, and four-wheel speed sensors that provide the Sport ABS computer with precise data to help the processor determine how to regulate the minute, millisecond reactions of lightweight hydraulic actuators that control braking loads.
Here is the link to the entire article:
http://www.fast-autos.net/mitsubishi...bishievo8.html
Hope this helps.
Chris
Old Jan 28, 2004 | 03:33 PM
olosports's Avatar
actually was looking for something along these lines if possible here is an example.
this is a wilwood caliper.
Old Jan 28, 2004 | 03:43 PM
Satori's Avatar
Nothing like that in the Evo manual. All they have is exploded views to show how the parts fit together properly.
This is the closest they come to that:
Old Jan 28, 2004 | 04:07 PM
olosports's Avatar
i really appreciate that but unfortunatly that doesnt help. the thing is i am trying to fit the brakes to another car, i love the evo but i have already gone really far with another vehicle i am very loyal to but it needs brakes and i love the brembo's on my buddies evo and i trust brembo so i figured they look like they would fit so if i can get ahold of the right info i can make it work, since they found a way to make porxche brakes fit.
please anyone else that may have more inf please help.......thanks1
Old Jan 28, 2004 | 07:01 PM
Contact Brembo via their website and give them the specs you need to see if they have a caliper/rotor setup that matches. There are so many cars that they make OEM or replacement systems for now, that it is highly likely they already have your application somewhere. Now trying to find an Alcon system that works is a different story...
Old Jan 28, 2004 | 07:03 PM
blonde's Avatar
man, me and you think exactly the same i talked to him last night and told him to contact brembo and ask them about this.
Old Jan 29, 2004 | 01:49 AM
Satori's Avatar
Please let us know here if you get any good info from Brembo. I understand these brakes are custom made for the Evo so it's not a normal product they sell, thus are not likely to have that information redily available.
Old Jan 29, 2004 | 07:16 AM
BPAuto's Avatar
Silver Sponsor
I'm guessing you're trying to bolt them on to a Volvo? I was under the impression the Brembo systems for the 350Z, STi and Evo are nearly the same. Visually, they look very similar.
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
Old Jan 29, 2004 | 07:18 AM
blonde's Avatar
i highly doubt that. i think that the EVO shares the same brake setup as the STI,350Z,SKYLINE and a bunch of other cars. it seems very unlikly that BREMBO will creat new calipars for all these cars when they can just use their F50 kit or the gran turismo kit. i might be mistaken so i would love to know more info on this as well.
Old Jan 30, 2004 | 08:22 AM
Maddmatt's Avatar
The Evo and STi are similar to one another, but different from the 350Z/Skyline.
Old Jan 30, 2004 | 04:43 PM
olosports's Avatar
i called brembo cant tell me anything on the stock app.'s er'
and yeah i am trying to bolt it to the volva. i appreciate everyones help if anyone else has any idea's please post. thanks!
Old Jan 30, 2004 | 08:33 PM
Satori's Avatar
Did you try ****syerbishi?
_des_
Sep 5, 2015 02:59 PM
Howulikemyevo
Jul 15, 2015 05:24 AM
Evo3573
17
May 22, 2015 11:42 AM
Faisalm
Jul 21, 2014 01:19 PM
