Fender rolling question
Old Jul 18, 2012 | 05:47 PM
  #31
Hi Im Vinh's Avatar
Originally Posted by zenoise
With +20 u do not need spacers. But with plus +30 do u need extended studs? Thats what subydude at wheeldude.com has told me. Btw if thats your ride it looks really nice. Flush. Thats the look i would love to achieve.
Yes , that is indeed my car in the picture. And yes, I had to do ARP extended studs upfront to fit that 12mm spacer due to the fact the bare minimum you can get a bolt-on spacer in is 15mm.
The fronts are flush with no rub or aggressive negative camber, I don't even rub on full steering wheel lock. Only a slight rub on the inner fender lining tab on the passenger side but I know why and is something minor that I overlooked.
As for the rears, I plan on doing 5mm spacers to flush it out and my only concern is if I can get away with running the spacers on my stock studs or will I have to go ARP studs. I've researched plenty and it seems to be 50/50 depending on wheel design and how safe you feel with leaving it that way lol.
Old Jul 18, 2012 | 08:36 PM
  #32
zenoise's Avatar
Counterconcept I havent deleted anything so the jokes on u bud. Must be someone else cause i dont even know how to delete post when using my phone. So keep trying to be funny or an *** whatever your trying to do. Once again i didnt delete squat. To be honest i was wondering what happened to some of the posts myself. Anyways keep up the negative posts guy.
Old Jul 18, 2012 | 08:38 PM
  #33
zenoise's Avatar
Hi im vinn thanks for the normal and informative response. I wish all posts where as simple and to the point as this
Old Jul 18, 2012 | 08:42 PM
  #34
GTijoejoe's Avatar
GTIjoe my question for u is who is CBRD? Just so i can look at any success they have had with fender trimming. Also what sealant would u recommend using after trimming? I am really thinking of going this route for many reasons. Cheaper, less risk of fender damage etc.. any tips would be great. Thanks for your time.
CBRD is a well respected shop in PA, their website kinda sux (sorry Chad, spade is a spade) but they are more then willing to help you if you called or PM'd them I'm sure!....
seach on the sight or google, Chad Block Racing Development... CBRD. You'll find it.
There is paint sealant, use paint, clear coat, and/or undercoat (black sticky stuff) would be the way to go.... all of the above, as long is it is sealed from the elements it should be find.
ps. you won't need to cut the entire lip off... that would be a mistake.. meaning... the entire lip from front to rear of the fender, and also the entire lip width making the fender lip flush with the outside surface. Make sense?
Old Jul 18, 2012 | 09:32 PM
  #35
zenoise's Avatar
Yes your info and fender trim is exactly what im gonna do. I am not gonna cut the whole thing off flush with the outside of the fender that would be just a stupid move. I am gonna go little by little to see what i can do to make it clear. This has been very helpful info. thank you
Old Jul 18, 2012 | 09:35 PM
  #36
zenoise's Avatar
Originally Posted by CounterConcept
Hahahah this zenoise guy deleting comments cuz he knows he was acting like a jackass to the suggestions people gave him.!! You should be careful before u lash out at people for trying to help you it could come back and bite you in the rear.
Also I am not sure if that is a threat but really dude i havent deleted anything. It would nice if whoever did spoke up so you would see I didnt delete anything but really its past I got my answer from someone and thats all that matters to me now.
Go ahead and keep saying im deleting posts or say im talking like a jackass i could care less so have a good one man.
Old Jul 18, 2012 | 09:41 PM
  #37
Blue91lx's Avatar
The OP asked for tips about fender rolling, and all he got was bashing.
For all of the high and mighty anti-stancers, tell me: what's your effective offset on your +30's with a 10mm spacer? Hmm......
OP your fronts will be easy to work around, but in the rear you will need to roll flat, do a moderate pull after rolling, and most likely re-locate the bumper tab. You'll rub where the quarter meets the bumper, so to solve that, you can cut the inner lip of the quarter at the bend so you can roll it flat, if that makes sense.
The dude even said he doesn't want to run camber, so he's clearly not going for stance, so yah'll can calm down.
Old Jul 18, 2012 | 09:43 PM
  #38
n2oiroc's Avatar
good points. and a lot of guys that claim no rubbing with +20 offsets and decent size tires, they have to drive like women if they dont rub stock fenders. heck, +30 9's with 255 star specs rubbed on my car.
Old Jul 18, 2012 | 09:45 PM
  #39
Blue91lx's Avatar
Oh, I know. I started a thread about a 265/35 and everyone claimed no rubbing after a roll/pull. I drive my car like a man and needless to say I only have half my sidewalls left .
(18x9.5 +27)
Old Jul 19, 2012 | 05:25 AM
  #40
GTijoejoe's Avatar
...For all of the high and mighty anti-stancers, tell me: what's your effective offset on your +30's with a 10mm spacer? Hmm......
I'm sorry, I'm bad at math, what does that come out to be again
Old Jul 19, 2012 | 06:42 AM
  #41
zenoise's Avatar
I guess sometimes u have to wait through all the nonsense to get to the posts that actually help. For the guys that posted the last few, thank you these posts they were very helpfull. Ill search for help on pulling fenders because that is not something im familiar with. Any tip, tricks etc... would be helpful tho.
Thanx again
Luke
Old Jul 19, 2012 | 07:18 AM
  #42
Solenoid's Avatar
Veteran: Marine Corps
Here's a tip. Dont attempt the roll / pull yourself. Have it professionally done
Old Jul 19, 2012 | 07:20 AM
  #43
Hi Im Vinh's Avatar
Thanx again
Luke
My tip to you is to have a pro do the fender rolling/pulling
Old Jul 19, 2012 | 07:34 AM
  #44
Blue91lx's Avatar
I would say watch YouTube videos and have a friend over to lend a hand for when you roll them, if you're mechanically inclined. You gotta start somewhere, so if you never try it you'll never learn. However, by all means if you don't feel comfortable doing it, don't even attempt it.
I just did my own fenders and they came out great. Use ample heat and take your time.
Old Jul 19, 2012 | 02:06 PM
  #45
n2oiroc's Avatar
ive had 6 people use my fender roller, only 2 guys had paint crack and they both said they were impatient and went too fast.
