master bushing kit questions
Old Sep 18, 2012 | 10:31 PM
shiny1's Avatar
I went to a suspension shop the other day to see what was causing a squeaking sound in my suspension. The report showed:
1. Front swaybar "D bushes worn"
2. Rear lateral arms "lower inner bush worn"
3. Rear trailing arms "lower trailing bushes fair/wearing"
4. Rear sway bar "D bushes worn"
What I'd like to know is - will a master bushing set from Energy Suspension ($140 + shipping costs) cover all these bushings? I looked at what was included and there are terms that I'm not sure about. Maybe there might be another name for the same thing like rear differential something something etc.
Included in the master bushing kit:
1. Front & rear control arm bushings
2. 24mm front sway bar bushings
3. 22mm spiral rear sway bar bushings
4. rear differential / mustache bar bushings
Just want to confirm before I put the order through.
Old Oct 11, 2012 | 05:39 PM
rick1024's Avatar
interested to know too
Old Oct 11, 2012 | 06:22 PM
Redbud23's Avatar
Veteran: Marine Corp
Bushings
Go to energysuspensionparts.com and look up which ones you need. The master kit will come with the front and rear sway bay bushings. It comes with the trail arms but not the other rear arm bushings you have to purchase some whiteline pieces. Which are from Australia so cool for you. I went ahead and bought a couple of whiteline stuff and it is very good stuff.
Thanks
Old Oct 11, 2012 | 07:22 PM
deylag's Avatar
The Energy Master Kit will cover those. On the other hand, you could go with Whiteline instead. The mustache bar bushings are available in a lot of different variants.
Old Oct 11, 2012 | 08:35 PM
rick1024's Avatar
i dug in a little deeper and found that i need to replace the spherical bushings with spherical bushings. so im not sure if getting a bushing kit is going to help much. i know something is worn out in the rear of the car, i get the clunking sound when driving over bumps
Old Oct 12, 2012 | 02:23 PM
WRC-LVR's Avatar
Check the rear lower trailing arm ball joint for play. I had one go bad on my MR. You will have to get the whole arm though as Mitsu doesnt sell any replacement ball joints for it
Old Oct 12, 2012 | 10:22 PM
rick1024's Avatar
****. how much does that go for
Nast_Nas
Outlander Sport
19
Sep 24, 2019 03:34 PM
OverBoostedEvo
For Sale - Part Outs
Apr 21, 2015 06:34 PM
OverBoostedEvo
Apr 21, 2015 06:30 PM
Liquid0401
May 10, 2014 04:32 PM
Solo II Evo
Sep 1, 2011 09:30 PM
