Weird bilstein install issue
Old Oct 7, 2012 | 09:20 PM
overdrive1's Avatar
I was trying to install a set of Evo MR bilstein front struts on my evo 9 and the strut length is way longer than stock and it doesnt align with the 2 bolt holes on the hub. It sits like 2 inches below it should be sitting. the strut mount bolts are tight so no more room to move up. any ideas ? do I have the wrong set of bilsteins ?
the stamped #'s on the bilstein is
MN101890
3905VE3 A900T0
in the 2nd pic you can see the height difference between the tein coilovers that came off the car and the bilsteins I want to install. both are standing on the floor and the sturt mount on the bilsteins sits 2" higher than the coilovers.
Attached Thumbnails Weird bilstein install issue-img_0698.jpg   Weird bilstein install issue-img_0711.jpg
Old Oct 7, 2012 | 10:00 PM
n2oiroc's Avatar
coilovers are always a lot shorter with less drop out. you need to have someone push down on the front lower control arm while you get a bolt in the lower holes. they will go in and they do look correct. the part # is also correct. with the rears you will most likely have to unbolt the lower lateral link to get the lower bolt in.
Old Oct 7, 2012 | 10:05 PM
deylag's Avatar
Based on experience, the MR bilstein shocks are identical to stock shocks in terms of physical dimensions. Did you try to lower the hub to mate the shock?
Old Oct 7, 2012 | 10:45 PM
overdrive1's Avatar
thats guys, that worked. Just needed a little force to push the hub down to line it up...
suddoth1
Aug 16, 2016 06:43 PM
nealeighc
May 2, 2015 01:46 PM
Deano_Engineer_
Feb 27, 2013 09:54 AM
Deano_Engineer_
Feb 4, 2013 07:40 AM
FERNO
85
Nov 20, 2011 07:13 AM
