Problems with brakes
Old Dec 10, 2012 | 06:27 PM
shrtstuff89's Avatar
so last weekend my brake line got torn up while driving, losing brakes while going 45mph. got home safely without brakes ~5 miles downshifting and e-braking. ordered technafit lines with super blue brake fluid.
well im having firestone do it so the work is warrantied. they installed the lines, apparently bled the brakes, and are still going slim to no pressure when braking. they claim that i drove it too far without brake pressure and it fried the system/got that much air into it.
my question is, whatd they likely mess up or forget to do (given they bled the brakes properly starting from furthest wheel)
Old Dec 10, 2012 | 06:54 PM
WikdEvo's Avatar
Sounds to me like they just didn't bleed the brakes properly.
Old Dec 10, 2012 | 07:12 PM
this is my thought, but what are the chances the abs system is messed up
Old Dec 11, 2012 | 10:54 AM
They claimed air got into the master cylinder and they had to bleed it 3-4 times to get it perfect
Old Dec 11, 2012 | 11:04 AM
korizmo's Avatar
So its fixed now? I bled my brakes for over an hour until i realized there was a bleader on my master cylinder. Damn all the wasted time.
Old Dec 12, 2012 | 08:04 AM
djdnav's Avatar
I'll tell you what they did, they only hit the outside bleeder valves. Each caliper has TWO!
Old Dec 12, 2012 | 08:32 AM
Smike's Avatar
I would not let Firestone touch that car. 2 bleeders, ABS system, master cyl needed to be bled.
Old Dec 12, 2012 | 08:37 AM
Raptord's Avatar
How do you bleed the master cylinder? I've searched a few times but have never found anything about it.
Old Dec 12, 2012 | 09:01 AM
Smike's Avatar
Bench bleeding is the best method.
Old Dec 12, 2012 | 07:52 PM
JDavenport's Avatar
^ This. They simply did not get it fully bled. I use the Motive bleeder and flush a ton of fluid through the system.
Old Dec 13, 2012 | 04:26 AM
Smike's Avatar
DuBBzEvo27
Sep 4, 2014 08:54 AM
jlldetroit
Dec 20, 2013 09:11 PM
grahamab
23
Aug 12, 2013 12:15 AM
johnnycage
44
Nov 6, 2012 02:23 AM
RSGuy
13
Sep 3, 2010 05:34 AM
