Please help Need alignment specs for 12 mr
Can anyone help with what proper alignment specs on 12 evo x mr?
Had alignment done at the dealer, rear specs were
Toe 0.33 lr camber 0.8 rr camber 0.7 toe 0.7
Total toe rear 0.28 thrust angle 0.19
Problem is the front was not adjusted because it was "in spec"
Lf 0.8 camber 4.1 caster 0.02 toe
Rf 0.8 camber 4.1 caster 0.05 toe
Front 0.07 total toe 0.01
After alignment
Lf 0.8 camber 4.1 caster 0.01 toe
Rf 0.8 camber 4.1 caster 0.00 toe
Lr 0.9 camber 0.13 toe
Rr 0.9 camber 0.12 toe
Total toe 0.25 thrust angle 0.00
Should the front end be adjusted even though within specs?
Again dealer gave to a 3rd party. The car pulls bad in the front can it be adjusted.
Usually place I go has electronics that as they torque bolts it lights up green when its dead on. I have seen beat up cars get set perfect, or is the evo that sensitive.
After alignment
evolutionm.net > Lancer Evolution 1-9 Forums > Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
if you daily the car, set the rear toe to 0 or it'll eat tires prematurely
front looks fine, so does rear aside from toe
goofygrin
88
Jul 24, 2022 08:22 PM
hispanicpanic
10
Mar 1, 2014 04:07 PM
LancerEVA06
Apr 16, 2008 10:15 PM
