Which bushings should I replace first?
Necro bump!
Where can I find these?
Nothing in the store:
http://www.freewebs.com/robispec/apps/webstore/
^Have you tried calling Robert Fuller aka Robispec directly? Its been a couple years since I last spoke with him however he was quite friendly so I'm sure he would love to chat with you.
I should do that I guess.
I'm way too OCD and like to plan out my modifications months in advance, but I guess it couldn't hurt to talk to the man and get some pricing info etc.
Absolutely worth a shot
I'm right there with you on this research **cough**obsessiveness in regards to researching things well in advance. I was looking through that rear diff sticky last week and saw a comment I posted back in 2010. 3 years later I finally pulled the trigger.
This place is a wealth of knowledge so all you need is some patience and a brain(at least 1/2 of it) and you can learn a lot from others like yourself who have already gone through it.
I tend to find suspension tuning and/or methodologies a little tricky though as its not as simple as slapping on random parts. It all needs to work together as a system. What may work great on a car with slicks could be terrible rocking street tires. Also, driver preference as well as the type of racing you are into really comes into play here.
So while it is nice to talk with folks on here and understand what they are doing it may not be best for you.
Someone like Robert who is very knowledgeable with the CT9A chassis should be able to provide insight and offer recommendations that will fit your goals based on what is most important to you.
Im like that as well. I research something and pull the trigger on a new part a year later. It has taken me almost as long as Ive been on these forums to decide on my current suspension setup, which in all fairness is a pretty mild setup. I'm just really indecisive.
Want to talk **** retentive and detail oriented?
Here is my sheet for (California specific) power mods alone:
https://docs.google.com/spreadsheet/...VE&usp=sharing
I tried figuring out what to replace on my high mileage evo also, I just ended up combing through different build threads to see what others used in their builds with similar goals to mine, here is what I ended up ordering
KCA388 - WHITELINE Front Roll center/bump steer - correction kit
KCA395 - WHITELINE Rear Bump steer - correction bushing
W0594 - WHITELINE Rear Trailing arm - lower front bushing
W0593 - WHITELINE Front Control arm - lower inner front bushing
PEP-SUS-400 - PERRING Perrin PSRS Offset Bushings Mitsubishi EVO 8/9/X 2003-2013
Is there anything else worth getting that I haven't addressed with these parts?
