Wheels and Tires???
Old Feb 23, 2013 | 11:22 PM
OC's Avatar
OC
Wheels and Tires???
I currently have 17x9.5 +20 wheels on my evo 9 with 235/45/17 tires. I was debating about getting new tires. What would be the best for these wheels? I was thinking 255/40/17. What you guys think the best size is for these wheels? Thanks.
Old Feb 24, 2013 | 09:40 AM
heel2toe's Avatar
I'd love to help you out however your question is a little vague. Please define "best" i.e. what are your goals for the car? There is no one "best" size as everything comes with benefits as well as sacrifices.
235 is too stretched and even a 245 is a little stretched however is doable. A good size would be either a 255/265/275 all 40 sidewalls.
Keep in mind the wider the tire, the more issues you may have with fitment between the fenders and suspension components. Given your aggressive offset I would venture a guess that you will run into rubbing issues with the body before your suspension components though.
You really need to give us more info first though so we can recommend the best size given your qualifications.
Old Feb 24, 2013 | 02:19 PM
ctfpevoVIII's Avatar
I would go with 255/40/17 as the overall diameter is on par with the stock 235/45/17. Do you have any rubbing issues with your setup?
Old Feb 24, 2013 | 02:30 PM
evil.evo's Avatar
Veteran: Army
FCOTM Winner
that's a pretty aggressive setup. you might need to take fender clearance into consideration for your setup.
if fender clearance isn't an issue, i'd go with a 265/40/17. that size is only off by .02 inches in diameter from stock and is closer to the stock diameter than 255/40/17.
Old Feb 24, 2013 | 03:35 PM
tehhobbs's Avatar
Keep in mind that tire size will vary from brand to brand, for example Starsepcs and feddys will run roughly 10mm wide of their advertised size. Give us a little more information as to what you are looking to do with the car.
Old Feb 25, 2013 | 01:23 PM
OC's Avatar
OC
Best as for dd. I never track my car. Its a dd and always will be. What I meant as best was looks and performance. I am also dropped on Tein S Tech Springs. I want a very aggressive look.
Old Feb 25, 2013 | 01:55 PM
chu's Avatar
chu
17x9.5 +20 and 255s aren't going to fit well unless you pull the rear fenders. I run 17x9.5 +24 with 255 and its really close. On a hard curb at the track, it would scrap ever so slightly...just brushing the tires.
Old Feb 25, 2013 | 02:12 PM
Neal@tirerack's Avatar
I wouldn't go any wider than the 255. Our 17x9.5 with 18mm offset comes right to fenders edge when using a 255. Some people can get away with slight camber adjustments, others fender lip roll with that combo.
Old Feb 26, 2013 | 12:48 PM
This sound about right^^^
+20 a terrible offset for any stock bodied EVO8/9 IMO. Most guys run the stretch & roll-in severe negative camber to fit. Even at +25 you would be looking at a roll/pull & bumper bolt to make it right in my book
Old Feb 28, 2013 | 02:24 PM
OC's Avatar
OC
I do have all my fenders rolled. Right now I have no issue with rubbing.
Old Feb 28, 2013 | 03:36 PM
Vaughn Performance's Avatar
[B]Best as for dd. I never track my car. Its a dd and always will be. [/B
.........]What I meant as best was looks and performance. I am also dropped on Tein S Tech Springs. I want a very aggressive look.
If your question stopped at the highlighted part, I would say just leave your stock wheels/tires on.
As far as what "looks" best is a matter of personal taste. What "works" best performance wise is running the narrowest tire you can without overheating it. Everybody likes running big meats, but if your not getting them up to temp your just hauling around extra unsprung weight. How much is too much or not enough depends on what your doing with the car.
If what your doing is purely for aesthetics though, I'd say just pick some rubber that fits square on the wheel so it's safe and leave it at that.
-Anthony
eliminator 429
Nov 23, 2016 09:45 AM
eliminator 429
Mar 30, 2016 05:47 PM
luvboost
Jan 29, 2012 12:16 AM
shrty10135
11
Mar 9, 2011 10:43 AM
george3
26
Sep 27, 2008 05:18 PM
